Question about Specialized Fuse One BMX Bike '09
Bearings was wondering why bearings are not sealed, and how can i get them to not feel so rough. i greased them with white lithium grease after cleaning entire axle and hub assembly.
    Champion:
    New Friend:
  • 219 Answers
Perhaps the bearing cup or cones are worn?
Posted on Jul 18, 2013
What grease or oil do i need to lubricate the bearings and wobble plate on my Karcher pressure washer.
Use a Teflon based grease. Contact an auto parts store to buy it. The grease is usually colored blue.
Jul 16, 2016 | Karcher Garden
Location location of grease joints on axle of troy bilt pony mowerny mower
some units have sealed bearings,,check and recheck, if you find them use a good lithium grease
Aug 11, 2014 | Garden
Proform ZE3 Elyptical screeches constantly
FOLLOW THIS STEPS AND FIX IT. God bless you Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Mar 22, 2013 | Exercise & Fitness
Pedal tention too tight
Step 1:
please proceed with this step . Happy new year and God bless you
Lubrication
Step 2:
Pedal Arms
Step 3:
Link Arms
Jan 01, 2013 | Exercise & Fitness
My proform spacesaver 500 eliptical is making a clicking sound
follow this steps and fix it. God bless you
Lubrication
Link Arms
Pedal Arms
Nov 30, 2012 | Exercise & Fitness
I have a Freespirit 110 Elliptical purchased from Sears some time ago. Recently, there is a grinding noise coming from the wheel, possibly worn bearings?
Link Arms 1
Pedal Arms 1
Oct 15, 2012 | Free Spirit FREESPIRIT CROSSTRAINER 970...
Noise from bearings
see this steps and fix it. God bless you
Pedal Arms 1
Link Arms 1
Lubrication 1
Oct 15, 2012 | Proform Pro Form Sears Elliptical Drive...
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
Squealing noise for no apparent reason rear wheel when freewheeling
Could be a bearing..
If there is a grease fitting - try pumping some grease into it..
Other than that - try some penetrating oil or white lithium grease where the bearing are..
Jul 09, 2009 | Mavic Ksyrium Elite Wheelset
Specialized Fuse One BMX Bike '09 Logo
42 people viewed this question
Top Specialized Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
ddfisch
Level 1 Expert
John Egan
John Egan
Are you a Specialized Cycling Expert? Answer questions, earn points and help others
