Question about Compaq Computers & Internet
How do i remove a harddrive power on password
  • Compaq Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer. When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
also
Click the "Start" button.
Double-click "User Accounts."
Select the user account you wish to change.
Select "Change My Password." If you wish to remove the password, select "Remove My Password."
also
Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password.
Just click In New password and Confirm new password, type the new password by just clicking, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer.
You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change Password
Posted on Jul 18, 2013
Hard drive door unscrewed and hard drive was hanging... Now this screen?
This is a network PXE boot screen. This is usually the last boot device it will try if it doesn't detect a HDD or cd/dvd drive with bootable media. You should be able to see a hard drive in bios, if not replce it and re-install your operating system.
Dec 25, 2012 | Computers & Internet
Entered built in HDD1 user password
Hello
as the bios was reset the harddrive password was removed from the bios memory.
To get the password unlocked you will need to remove the harddrive from the laptop, buy a adapter so you can connect it to your pc and then do a few things Il tell you about later if your going to do it.
otherwice you can take the harddrive to a shop to be unlocked / reset to defaults.
May 10, 2008 | Iwill P4ES Motherboard
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
Apr 28, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
How to reset Hdd1/ssd1 forgotten password?
A) To resolve the initial BIOS lockout, download the most recent BIOS firmware, and flash the system if possible.
[ Note*
1) IF, there is a power outage at your home/business, when flashing the BIOS, your motherboard becomes an expensive paperweight.
It isn't it may happen, it IS do Not lose power, or this will happen. However this goes with number 2 below also,
2) When flashing the BIOS program it will be asked (Should) if you wish to create a backup, before proceeding to the flash.
The answer is Y-E-S.
Should something happen as briefly described above, you will have the original BIOS program backup to go back to ]
B) Then remove your harddrive, install it into an economical 2.5 SATA external enclosure, and pull your personal info off by attaching the external enclosure's USB cable, to a working computer.
Then reinstall the harddrive, and use the Recovery Disk to Repair.
(Non-Destructive Installation)
You May be forced however, to perform a Full Installation instead.
(Destructive Installation)
You will have your personal information because you saved it. You will however, have to reinstall programs/applications.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Harddrives come in two different sizes, and technologies, at present.
A harddrive is measured across it's Width.
A laptop harddrive is 2-1/2 inches across.
A desktop harddrive is 3-1/2 inches across.
The two technologies being used at present for harddrives, is IDE (PATA), and SATA.
The Satellite L455D series uses a 2.5 inch SATA harddrive,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,P000506260.aspx
{ Not stating the original harddrive was an Hitachi. Showing that the harddrive uses the SATA technology. It is already known that the size is 2.5
It is a laptop harddrive }
This is information on IDE (PATA) technology,
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
This is information on SATA technology,
http://en.wikipedia.org/wiki/Serial_ATA
This is but one example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Use Anti-Static Precautions when working on your laptop.
Be Sure ALL power is removed. AC adapter (Charger) and Battery.
Dec 01, 2011 | Toshiba Satellite L455D-S5976 Notebook
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have an acer travelmate 7730g. I turned off the fingerprint securlty and am now presented with a password request before anything boots up. The thing is I don't remember ever setting this password...
I ran into the same issue with a bios password The laptop is a newer Acer TravelMate and I was able to remove the password. Remove the hardrive first. Then remove the memory and unplug the black and red wires from the battery about 2 inches away wait a then plug it back in. With the harddrive out still I turned the computer back on and then back off, put the harddrive back in.
You will end up clearing the bios settings including the fingerprint readers settings.
May 16, 2011 | Acer Computers & Internet
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
EMACHINES T3522 Message "ENTER PASSWORD TO UNLOCK SYSTEM" ON STARTUP
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3522 Chat with a tech. I think a system password has been set by someone. Most probably a bios / HDD password. So you need to know that to boot. Bios reset may do the trick (by removing cmos battery). But you have to set the settings back to normal in BIOS. But if you have encrypted data you may harm them. (Rarely).
May 29, 2010 | eMachines T3604 PC Desktop
Trying to find a way to reset or bypass the HDD1 user password on my Toshiba A135-4527 laptop. It was reset somehow to something we do not remember. Hoping I do not have to replace the harddrive. Saw...
The hard drive password is set from the BIOS configuration where the hard drive was installed and you need to know the password to remove the existing password. You can only remove the password from that computer's BIOS and moving the hard drive to another omputer will not allow you to remove the password or access any data on that hard drive because the password is stored in the hard drive's firmware. This password protected hard drives prevents unauthorized access to the data on that hard disk.
Removing the BIOS battery will reset the BIOS but will not remove the password.
Some computers have been setup with Power On Passwords and/or hard drive passords and it is possible to hack/read the Power On Password that is stored on an EEPROM chip on the laptop, but it is not a simple process.
You will need to buy a new hard drive and now you also have a nice paper weight.
Feb 19, 2009 | Toshiba Satellite A135-S4527 Notebook
NEED PASSWORDS TO ACCESS HARD DRIVE
Sharon, you have a extremly difficult problem.
Why is the laptop in for repair, is the laptop faulty, how do you know the hard drive is faulty when you cannot start up the laptop?
It appears that you have or someone has set up a power on password and possibly a password protection on the hard drive.
If you hard drive is faulty it is highly unlikely that you cannot retrieve any data off your hard drive with or without the passwords.
IBM ThinkPads laptops store the Power On password on an EEPROM chip and removing the BIOS battery cannot clear this password. there are no backdoor passwords that you can use. The passwords are used to prevent unauthorized access to the laptop and its data.
If there isn't a password on the hard disk, and the hard disk is not faulty, you can remove the hard drive and connect it to a working computer to read and copy off your data. I suggest you connect your hard drive using a USB hard drive adapter and connecting it to a working computer's USB port.
IBM states that if you don't know the Power On password, therefore you cannot get into the BIOS to remove the password, and you need to replace the motherboard (this is not cheap).
There is a way to hack into the laptop, it required some electronic experience to build a reader device, dismantle the laptop, solder it to the EEPROM chip, connect the output to a working computer, run a reader program, locate the password from this data, unsolder the wires, put the laptop back together and boot up and enter the password.
For detailed information go to www.allservice.ro/forum
I have successfully removed these passwords, it is a lot of work, and needs to be tackled by an experienced person.
Best of luck.
Dec 18, 2008 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
