Question about Spa Choice Clear & Sparkle Spa Water Clarifier 16 oz. - CA1009
No directions for use on my bottle of SPA Choice - Clear & Sparkle
Can you tell how much product I should use in my 800 gallon spa.
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Im replacing a 6 hp pump with one they say is the same hp but the motor is rated at 3 hp. I dont understand can the wet end double the hp ?
Motor companies have been playing games with horsepower for a long time. The acid test is to look at the factory issued flow output chart with regard to gallons per minute and total dynamic head. That way you can tell if the two pumps are comperable.
Aug 22, 2013 | ADVANTAGE SonfarrelMartec Spa Master Spa...
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
I have a 8500 gallon Intex pool (12x24) with a saltwater system. My pool was looking a little cloudy and the Ph was high. I added a small amount Malic Acid yesterday and now my pool is green today. Any...
First thing to do with a new set up is remove the metal. The green is very likely copper in the water. Use a sequestering agent to remove the metal. Follow the directions on the bottle.
Second, establish the alkalinity at any number between 80 and 120 with 100 being the goal. Use Bicarb of Soda to increase or Muratic Acid to reduce.
When you have alkalinity of 100, try to get the pH at any number between 7.2 and 7.8 with 7.4 being the goal. Carb of soda to increase the pH and use Muratic acid to reduce. Move slow.
When the Alkalinity is at 100 and the pH is at 7.4 introduce Chlorine. The goal should be between 4 ppm and 10 ppm, since you are not an inspected pool. You should introduce Cyanuric Adic (AKA stabilizer) to a number between 50 and 80 ppm. Stabilizer will protect your chlorine, the chlorine you will be making from the salt in the water.
Next establish the salt level ata the point required by your system. I dont know what Intex requires in fact. I think it is a number between 2600 and 3400 - olease refer to your manufacturers instruction for this. Introduce the salt through a skimmer for best results. BTW, the water has to be hotter than 55 degrees F for your salt cell to make salt.
The Green could be algae - treat by super chlorinating your pool with liquid or powdered chlorine of your choice. I suggest at least 20 ppm.
Cloudiness is undisolved solids. Best way to clear this is by running the filter. The longer you run the filter, the cleaner will be the water. You can use a product called Super Blue which will aid in clearing the solids from the water. If you are impatient, you can use a flocking agent in the filter. I dont think you relly need it, however.
Tell me more about your pool is it rectangular at 12 X 24 (how deep) or is it 12 feet round 24 inches deep. I was trying to calculate the actual gallons. Provide the info and I will get the gallons though you claimit is 8500.
Thanks for your question @ FixYa.com ... please come again any time. Please remember to evaluate the response.
Jul 27, 2011 | Intex Automatic Salt Water System for ...
Ph level too high
Simply get a bottle of ph down and follow directions for your gallons of pool water
Jun 24, 2010 | Intex Automatic Salt Water System for ...
My acqua bot turbo doesn't move. Can you tell me where the nearest repair service dept is to my home address. Brick, NJ my email is mdaniele23@comcast.net Thank you in advance for your help. Mary Ann...
Ask them directly at:
General Contact Info
Aqua Products, Inc.
25 Rutgers Avenue
Cedar Grove NJ 07009
Phone Number: (800) 221-1750
Fax Number: (973) 857-8981
Email: info@aquaproducts.com
Hours of Operation:
Monday-Friday 9AM - 5PM EST.
Sep 24, 2009 | Pool & Spa
Spa Choice Clear & Sparkle Spa Water Clarifier 16 oz. - CA1009 Logo
420 people viewed this question
Top Spa Choice Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Spa Choice Fish Expert? Answer questions, earn points and help others
