Question about Rocketfish RFWHP01 Wireless Headphones
If I turn TV sound to zero and press volume + on headphones I get no volume response. The wiring is the same as it was before I replaced batteries.
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
My 19in lcd hdtv emerson wont stop turning the volume down by its self.And then i took my batteries out of the remote and it is still doing the same thing. i cant even press buttons on the remote. Also...
See if the minus volume button on the TV is stuck. With the TV off press the various buttons while keeping your ears close to them. Each will produce a distinct click when you press them, confirm if the volume - key also produces the same sound - if not the key is defective or stuck.
Jun 02, 2011 | Emerson LC320EM8 32 in. LCD TV
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
Using headphones the volume is on full, i can take the telly controle down to zero but the headphones are still full on how can i reduce the volume
If you glance at your user manual, you will find that the headphone amplifier is separate to the TV amplifier.
Go into the sound menu and turn the headphones down to the level you require.
Hope that helps
Jan 13, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
Dec 30, 2009 | Televison & Video
I plug in headphones, but sound still comes out of TV speakers
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV? o Connect the headphone cable to the headphone jack on the side of your TV. o The sound will be heard through both the headphones and on the TV speakers. o Press Mute to hear sound only through the headphones. o Use the volume buttons on the remote to adjust the volume level. o You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
Jun 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Dec 26, 2008 | Hitachi 26HDL52 26 in. LCD Television
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Rocketfish RFWHP01 Wireless Headphones Logo
26 people viewed this question
Top Rocketfish Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rocketfish Audio Player and Recorder Expert? Answer questions, earn points and help others
