Question about Rocketfish RFWHP01 Wireless Headphones
My head phones RBW P01 stopped working. Replaced with new chargeable batteries. but if I turn the TZ sound down to zero, there is no sound in headphones. Pressing the + volume on the headphone does not produce sound. My only purpose is to hear TV thru the headphones while the volume in the TV is zero so my wife can sleep.
I have a DC3 B&H 10 Mega Pixel digital camera that won't turn on even new batteries. What could be the problem?
When you say 'new batteries' are you using re-chargeable NiMH batteries, or standard store-bought ones ? You may find that by using re-chargeable batteries, sufficient power is provided for the camera to work - this is why so many cameras use proprietary rechargeable batteries.
Dec 28, 2016 | Digital Camera Cameras
Timecutter 42 kholer electrical problem
The battery may not be chargeable and will have to be replaced.
Apr 20, 2014 | Simplicity 42 Toro Timecutter 20hp Kohler...
I have had my i phone for three days but will not charge beyond 50..percent...help
If the re-chargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 14, 2012 | Apple iPhone 5
Canon Powershot SX120is wont turn on
This kind of problem happen because not all of AAA batteries in market are match with canon standards. so changed his mind about using disposable batteries on new models. your camera need new DC/DC board which is expensive(between 50 to 90 dollars). there is video in you tube to how replacing the board. But better suggestion is getting a new camera with chargeable battery.
May 28, 2012 | Canon PowerShot SX120 IS Digital Camera
I have a wirless xbox 360 headset and it was working about 4 days ago and I had it on charge when it died when I went to charge it wouldn't charge or turn on and I have had it to long to take back to...
so you are saying that you have a chargeable microsoft headset and the last time you tired to charge it. it would not work... it sounds like your rechargeable battery is dead and you might need a new one. also try you head set on a friends unit and see if it works, at the same time take their chargeable battery and place it in your headset and see if it works that will tell you if it is your headset or the battery..
game tag DeepReserve
May 19, 2011 | Microsoft Wireless Headset for Xbox 360
The power keeps turning off, the phone is fully charged. I turn the power on and 5 min.later the power is off and I don't receive calls.
How old is the phone? You might be falling into a case of a dead battery. Usually the life span of a good battery can last up to 2 years with good charging care. However, without proper care, chargeable batteries can die within a year. Try taking the battery out and plugging the phone in and seeing if that works. If it does. you may just have to buy a new battery.
May 04, 2011 | Cell Phones
Hi I have a Panasonic Luminex DMC-TZ%, but everytime i swap the battery the time date function re-sets to zero: 1 jan 2000, just like an old 35mm film camera when the internal battery when flat. Any ideas...
There is probably an additional battery (usually a button battery) that keeps the internal memory going when there is no battery. It needs to be replaced.
Aug 12, 2010 | Cameras
Reset p01
reset po1 means reset the actual head unit the is a reset button on them you press down for a leat 5 seconds or pull the wiring out of the back of the unit or you may also disconect the battery for one minite so the unit loses its memory and then do all your settings again and it should be fine
Apr 27, 2008 | JVC Sirius KD-LH300 CD Player
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Rocketfish RFWHP01 Wireless Headphones Logo
Top Rocketfish Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rocketfish Audio Player and Recorder Expert? Answer questions, earn points and help others
