Question about Kenmore Washing Machines
Kenmore 110 92596100 washing machine
Water won't drain and washing machine won't do anything
  • 97 Answers
SOURCE: water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
  • 30 Answers
SOURCE: My kenmore washing machine will not drain.
Possible pump blockage but before checking ,get the flexible drain hose to its lowest point and drain water into a bucket good luck hope this helps
Posted on Aug 09, 2009
  • 1937 Answers
SOURCE: kenmore 70 series washing machine won't drain or
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Nov 05, 2009
erpaalai
  • 999 Answers
SOURCE: how do i drain water from the washing machine
Disconnect the pump hoses will do the trick.
Eric
Posted on May 20, 2010
heatman101
  • 43501 Answers
SOURCE: Washing machine won't rinse and
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 04, 2011
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Kenmore front load 110.46462501 mid cycle all lights flash won't drain
Check your drain pump/filter may be located bottom right of machine/hold drain hose over bucket with around 2 feet from floor level should pump if no blockage....Remove any blockage .hope this also solves tray fault
Jun 27, 2012 | Kenmore Front Load Washer
Water will not drain out of the washing machine and won't complete cycle.
heatman101
Sep 10, 2011 | Kenmore Washing Machines
My washing machine won't drain what can i do
I f you have tried resetting the breaker and then choosing the drain/ spin option and this didn't work.....you will need to get a large bucket and disconnect the drainhose from the back of the unit and allow the water to flow into the bucket. You may have something stuck in the pump...
Sep 01, 2011 | Kenmore Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
heatman101
Aug 14, 2011 | Kenmore Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
