Supermicro C2SBA+II motherboard all hooked up but won't start. There is power as indicated by the inside LED being on. Help troubleshooting?
After much angst and research and a couple of helpful solutions from Fixya Experts I have discovered that my motherboard is a Supermicro C2SBA+II motherboard. I was able to locate a manual online and connect the correct wires to the corresponding pegs. I press the power button, nothing. How do I troubleshoot to see if it is the motherboard or the power button?
    Brigadier General:
  • 3,400 Answers
Posted on Jul 17, 2013
map9966
  • 2351 Answers
SOURCE: abit motherboard nf-m2s
Hi chatzmoe, on page 8 of you're manual is a picture & layout for you're abit NF-M2S front panel connectors for LED's.
If you're current manual does not show this, tham download the manual from the link below.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF-M2S&fMTYPE=Socket%20AM2&pPRODINFO=Manual
Main web page for Abit NF-M2S.
Have more questions? Please feel free to ask.
Luck!
Mike
Posted on May 08, 2008
rhoncruz
  • 134 Answers
SOURCE: trouble locating panel1 wiring for EliteGroup 945G-M3 MOBO
I hope it helps!!!
Posted on Nov 30, 2008
  • 53 Answers
SOURCE: wires connection
If you know where the board came from i.e. a dell laptop model number or dell desktop model number this would help.
The issue is this is a Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} propretary version of the motherboard and can have different configurations based on what machine you got it from.
This is a link to the Dell Dimesion 8400 spec for that board.
The E210882 is commonly the D865GLC motherboard from intel spec is here.
Posted on Jan 30, 2009
the_fire
  • 432 Answers
SOURCE: Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Posted on Apr 13, 2009
  • 8 Answers
SOURCE: need manual for ms9138d motherboard
http://safemanuals.com/user-guide-instructions-owner-manual/MATSONIC/MS9138D-SERIES-VERSION-1-3A-_E check this web page there are manuals for sale and user guide for download. If this is no help do a seach from google ie:ms9138d manual usually the d or e on the end is a minor difference in the board but you should be able to find the exact board notice there are even versions of that board!
Posted on Sep 05, 2009
H8SMI-2 (rev:2.01) motherboard won't post. On-board power led does not light. Fans run, but that's all.
Just check if you are giving enough power to the motherboard check if all the wires are connected and in place.
Sep 28, 2013 | SuperMicro H8SMi-2 Workstation Board -...
Supermicro x9dai won't post, beep, boot or much of anything else
this motherboard won't work with latest v2 cpu's from intel , until you upgrade your bios to 3.0 version.(you must plug your 8pin conector for cpu's , both of them !!!!!).So you must start the mb with an older cpu , then upgrade bios .
Dec 08, 2012 | SuperMicro Computers & Internet
How to hook my power switch to my asus motherboard?
the front pannel on the mother board will be indicated some ware in the mortherboard the function is tha a3.3v must be shorted to ground for the computer to start if you have a multi tester then check the pin for voltage and short in with 0v the power switch will be different in motherboard the sequence of the front pannel is 10 Pin Panel connector (IDE LED, Power LED, Power Switch, Reset)
Jun 02, 2011 | ASUS P4VP-MX Motherboard
Hi! I get Supermicro U2 server with X5DPA-GG MBO. Cpu and memor modules are ok, but when I turn on server I get long error beep. I took manual and saw that's overheat problem (or should be). But server...
This sounds like a video controller issue. Try booting with a different monitor. Ensure the cables are connected to the motherboard correctly (fans/power/led indicators). Try booting off of a single stick of RAM. Otherwise you may need to check the warranty status and RMA the motherboard to have it repaired/replaced.
1 beep: circuits reset - ready to power up
5 short, 1 long: memory issue
8 beeps: video adapter issue
Feb 21, 2011 | SuperMicro X5DPA-GG Dual Xeon/E7501/FSB...
Hello, I have buy a Supermicro X8DAH+. I have mount 2 x Intel X5670 on the motherboard. When I push the button to start the system, the power is on, the fans run, I ear one beep but the power led...
I dont have specific info on this board, but most of the time you may need to set up a jumper to support 2 cpu's or with the 1 installed go into bios and see if there is a setting there that you can set. Another possibility may be the other chip is bad...swap the 2 out to see if it works...then you can rule that out...go to www.supermicro.com/manuals/motherboard/5500/MNL-1060.pdf...this is the manual for it...
Dec 20, 2010 | SuperMicro X8DAH+ Server Board X8DAH+O...
Won't power on. standby 5v warning led is on.
You could have a probelm with the connection where the power supply connects to the motherboard or you may have a bad power supply. If you have a power supply tester, try testing the power supply first. If it pass, you may need to replace your board.
Good Luck
C2Solutions
Aug 03, 2009 | SuperMicro P4SGE (P4SGEBULK) Motherboard
Waste ink near full is coming up on the screen
Sounds like you have to empty the waste toner ink in your printer.
Regards.
Jul 20, 2009 | SuperMicro CORE2 DUO/QUAD, LGA775, FSB...
SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
X7DAE at the time of boot stuck on logo
the broblem is probably your keyboard, since del doesn't work then this indicates that your keyboard could have some wires cut from inside the wire casing due to various reasons or the keyboard plug isn't well attached to the wires or have some bent pins.
my advice : go buy a new keyboard.
Dec 21, 2007 | SuperMicro X7DAE Motherboard
Can not find Serial ATA II 1TB HDD
page 62 will show you to set up your sata harddrive. It looks like you set it to auto, and let the BIOS find it
http://www.supermicro.com/manuals/motherboard/5000X/MNL-0876.pdf
Let me know how you make out.
Dec 06, 2007 | SuperMicro X7DAL-E Motherboard
Computers & Internet Logo
973 people viewed this question
David Payne
David Payne
