Question about Whirlpool Washing Machines
Whirlpool he washing machine not filling. Model #wtw4850xq0
Washing machine is not filling with clothes in it or it will not fill in the cleaning mode. unit is he. circuit panel is w10367783
4 Suggested Answers
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
kapishtech
  • 2272 Answers
SOURCE: Washing maching not filling with water
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
Model WTW4850XQ0 will not fill up with water, just stops after sensing cycle
I have a WTW4815EW0 whirlpool washer that would not fill to appropriate level when selected. So deep water wash was 2" water. I found the "water level hose" back rt and vibrated it by hitting it for about 30 times like strumming a guitar string, and voila now I have deep water in deep cycles. To reach this hose you have to have water in the drum so you can reach back there and feel for the hose.
Jul 09, 2017 | Washing Machines
How much load in one time at washing machine?
if you fill it half full that will be considered full load. as I own a laundromat and best results are fill half full it leaves cloths room to move, as well it wont stress motor and other critical parts.
Nov 04, 2016 | Whirlpool Washing Machines
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool duet Washing Machines
Does the Model #WTW7340XW2 Whirlpool clothes washer delay cycle fill with water before the delay cycle begins. Can I use this cycle as a soak cycle? Thank you, Shiela Walker
Hello, After looking at your service book no it should not fill untill it starts the cycle. Sorry...If this helps please rate me. Thank You :)
Jun 09, 2011 | Whirlpool Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
When I wash our clothes, rust stains are on the
Sure sounds like it, however, before anything else, I would shut the water off, remove the hoses, and fill 2 buckets once with the cold, then once with the hot to make sure it's not your water supply.
You'll need to fill them, and let them set for a while to see if anything has settled to the bottom. If they check O.K. then
I would call a local appliance parts house that carries Whirlpool parts. With the complete model number ask them if they carry the tub. If yes, then ask how many have they sold in the last 90 days.
If they have been selling them, then yes, your probably a good candidate. I'd call around for prices, it's fairly expensive.
Jun 25, 2010 | Whirlpool WTW5520S Top Load Washer
Won't fill
Try putting the clothes in and filling it with a bucket via the top opening (Cold water will do)
If it starts and washes then it is the fill valve which has gone faulty , if you put in the normal fill level and then exceed by say another bucket full, that indicates it is the pressure switch.
Ps
You might try taking the fill hose off the back of the amchine and clean out the small filter which is just inside the opening
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
