Question about Dryers
Temp goes up to hi when air goes on - Dryers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model dryer?
Posted on Jul 17, 2013
My D-Max 2010 is over heating
Check your water pump and thermostat for proper operation
Jan 11, 2017 | Cars & Trucks
Hi my honda cb1300 .on a run the temp is 80 .but when i pull up the temp soon goes up to 100 is this normal
it indicates a failure of the cooling system fan ( if fitted)
coolant is cooled by air passing through the radiator so when riding the road speed provides the air flow and so the temp is normal but when stationary there is no air flow so the temp will rise
If there is a fan fitted the check the fan,fan relay or coolant sensor for correct operation
If not fitted then it could be considered normal as there is no air movement to do the cooling
The same thing happens when the engine is shut off as there is no coolant circulation there is still residual heat in the metal of the engine and so there will be a rise in temp as that heat moves to the coolant
talk with a service center and discuss what could be a normal temp rise when stationary to determine if you have a problem
Jul 05, 2016 | Honda Cars & Trucks
Heat goes in and out and the temp gauge goes up and down
Your temp sensor has nothing to do with your heater. The temp sensor needs coolant in order to work properly. So first check the coolant level because if it is low your heater will act the way you describe. Once the coolant gets low enough the heater will blow cold. Another possibility is the radiator cap. After the engine has warmed up it expands when it cools down it contracts. As it is contracting if the cap is weak air can be drawn into the system and cause air pockets to form and will cause the same problem
Feb 09, 2013 | 2000 Pontiac Grand Prix
When I press the control to get the air temp down to 60 it goes back to 86 right away , How can I fix it ? I have a Haire portablr air cond 7000 btu model hprbo7xc7
most air conditioning unit have a built in thermometer so that it will tell you the room temp,if you set the temp and then it goes to a high number let the system rum for a while and see if the temp starts to go down in the room it is probably working fine.
Jul 21, 2011 | Haier Heating & Cooling
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
Temp gauge goes to hot and engine looses power.
hi.. your coolant temp sensor may be getting a bad reading, it also opperates as a compensator so it may effect the power of the vehicle.. check that the engine is actualy hot when it says and your car will probably run alot better if you change it anyway..
Feb 10, 2010 | 2001 Pontiac Aztek
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dryers Logo
15 people viewed this question
Top Dryers Experts
