Question about Microwave Ovens
Whirlpool microwave gold
The button you click to open the door has broken from the inside. In order to fix it you have to take the black cover off but there are these unique screws holding it on. Its like a hex screw except there is a metal peice in the middle of the screw. Is there a special bit that you can buy to take the screws out?
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
No, is only set for numerous screw manufactured in China
God bless you
Posted on Jul 18, 2013
FRANKSFIXIT
  • 72 Answers
SOURCE: Lightbulb in Emerson microwave model MW8115 SS
You have 3 choices to use on removing the safety screw(s) on the MW (microwave or nuker as I call them) cover.
1 - The screw(s) is/are usually a modified TORX T-20 or T-25 bit adapter. Sometimes you can very carefully use a standard T-20/25 bit adapter to get the screw loosened. Sometimes! If that doesn't work then you have option #2.
2 - If #1 doesn't work you can use a small flat blade screwdriver that has been modified with a slot cut into the center of the blade end to bypass the center pin. First find a narrow enough flat blade srewdriver that you don't care about anymore, and make sure it fits rather snugly inside the screw-head just for a loose fit. If the blade is a bit wider - no problem - it can be ground down to fit snugly. Next - using a dremel tool and diamond cutting wheel attachment (or similar) cut a slot into the end of the blade. Make sure that the screwdriver is going to bite the insides of that screw-head first though before wasting a perfectly good screwdriver. You will have to adjust by trial and error until you get the blade to fit perfectly the head of the safety screw. If the screws are really tight use a pair of vice grips to clamp the screwdriver blade for extra leverage.
If neither of these methods work for you or you can't modify a special tool then you will have to do the last option.
3 - Using an easy out of proper size drill out the center pin and then use the proper "easy out" to back out the screw. Discard that/those screw(s) and replace with regular phillips head screws after replacing the light bulb.
Hopefully you will be able to do this repair yourself? Otherwise if your neighbor is Tim the Toolman Taylor I'm sure he'll be able to give you the necessary hand to do it for you.
Hope this helps fix your dilema you are in.
One note here -
Make sure you unplug the nuker first and be VERY CAREFUL as to NOT TOUCH the HIGH VOLTAGE CAPACITOR inside. Otherwise you risk a chance of SEVERE HIGH VOLTAGE SHOCK!!!!!!!!!
BE VERY CAREFUL....
Best regards,
Frank
Posted on Mar 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool Microwave GT4175SPS0 - door
This model appears to be a counter top model (if not, please reply back, since procedure differs).
You will first need to unplug the unit and remove the outer cover.
Then you'll be able to see inside where the door open button presses on the release lever, which lifts up the hook-like projections (latches) on the door so that the door will open.
Usually the part that breaks is the release lever.
You can find helpful exploded views for similar models (such as the GT4185) here, but your best bet is to call the number at that site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
SOURCE: I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
Posted on May 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: How to replace cracked plastic door frame on Whirlpool microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 20, 2009
milten1
  • 1304 Answers
SOURCE: Problem: How can I replace the door handle on a
ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
Posted on Oct 10, 2009
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Button to door opener is broken. How do I fix it.
You can find handy exploded views and order parts by model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 27, 2010 | Whirlpool Microwave Ovens
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Broken door opener button
sounds like the door latch hook is broken you will have to seek a repair man for this
Feb 12, 2010 | Whirlpool GT4185SK Microwave Oven
I have whirlpool model GT4175SP.after heating a dish i cannot open the door as it has no spring action and microwave does not work. but there is power and light. jay
It may be a broken door open lever or a worn or broken door open button, or possibly the spring mount for the door latch heads (hook-like projections) may be off inside the door.
If it's an owner the range type, you can likely get to and replace the door latch parts by just removing the control panel assembly.
If you have to remove it from the wall to remove the cover, y
ou can download Whirlpool owner's manuals and installation instructions here.
If it's a counter top unit, you will need to remove the outer cover to get to the door latching parts, in which case you can see these files: safety disassembly.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 25, 2009 | Whirlpool Microwave Ovens
Button to open door is broken & ice cream is stuck inside!
For the microwave door you can go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MH7140XF
and click on your model number. Then in the next window click on the diagrams in the left-hand side to see an assembly view of your unit.
Mar 31, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool Gold microwave doesn't heat
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
http://www.microwavedisplay.com/doorsw.txt
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Dec 07, 2008 | Microwave Ovens
My Whirlpool microwave gold start button is not connecting. When I close the microwave door if I do not adjust the door, then press start, then press reheat and hold the reheat button for the duration of...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you only need a switch, you can order a universal type from us for $5 postpaid.
Nov 19, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
