Question about Fish
How to reapair skimmer - Fish
What are the main types of aquarium skimmers?
The main types of aquarium skimmers are: Air Driven CC skimmers, Venturi skimmers, downdraft skimmers, and aspirating skimmers. For more detailed information about these skimmers, check out this website: http://reefkeeping.com/issues/2002-06/fm/feature/index.php.
Sep 05, 2012 | Fish
Which hang-in skimmer should I get?
For a hang-in skimmer I'll advise you to pick the SeaClone skimmer which is the best hang-in skimmer on the market although it can get quite expensive.
Aug 30, 2012 | A H Fabrications Fish
How much should I spend on a new aquarium skimmer?
As far as cost, aquarium skimmers can range anywhere from about 60$ to hundreds of dollars, all depend on how quality the skimmer is.
What is a two pump skimmer?
There are some skimmers who use two pumps, one for pumping water through the skimmer, one for inducing air into the water with a needle wheel. For instance the Red Sea C-Skim 1200 use two pumps.
What is a Co-Current protein skimmer?
Co-current protein skimmer is one of the methods used in aquarium water skimmers. The air source is on the bottom of the reaction tube. Water is drawn up into the chamber with minimum dwell time. This skimmer is the least efficient of all skimmer designs.
What is counter current protein skimmer?
A counter current is one of the methods used in aquarium water skimmers. The water to be processed enters the skimmer reaction chamber, then the air administered through a diffuser. The water flowing downward meets the bubble column flowing upward, this increases dwell time making the skimmer much more efficient.
What are the top skimmers picks?
The five most recommended aquarium skimmers are: Aqua Medic Turboflotor 1000 blue hang-on skimmer, Aqua C Remora protein skimmer, AquaticLife internal mini skimmer 115, Eshopps hang-on tank protein skimmer and the Lee's Counter Current protein skimmer. Each has its own benefit.
I just brought a new skimmer and it seems to be bubbling over. Is that normal?
It is totally normal foryour skimmer to bubble over once you've initially set it up. I would lower the water lever in the skimmeruntil it still bubbles but does not overflow. It is ideal to have a foamy layer of bubbles just below the top of theskimmer.
May 13, 2012 | Fish
Just had pool opened. They turned port dial to 2
Welcome to FixYa
Dear Sir/Madom,
If your skimmer is tied to your main drain, then both holes have to be uncovered for your skimmer to work.
If you have a separate line all the way back to your equipment from your main drain, then you may want to try to open both holes in the skimmers. Turn off your Unit to unscrew the retaining screw on the valve, and then slide the big end over.
If you've not had your pool run all winter, then you may have leaves/debris caught in the line.
If so-you can swing by a plumbing supply house and get a powerflush hose attachment.
  • Make sure that none of the holes in any of your skimmers are covered by the oval tab in the skimmer.
  • Then, if you have any valves on the inlet to pool pump, rotate them in such a manner to isolate the skimmer line that isn't working, making sure that it is open.
  • Place the hose and powerflush device in the upper inlet port of the pool pump, with the pump lid/cover and basket removed. Then, pressurize the line back to the pool with tap water.
  • If it doesn't release right away, then let it sit a little while, as you may have to "pulse" it as water pressure drops as water leaks around the clog.
  • Pulsing it means to turn the water on for a few minutes, then turn it off. Then, turn it back on, and then turn it off again.
Look down into the bottom of the skimmer. It will have either one or two holes, depending on your model. These holes are where the pool plumbing attaches to the skimmer. Most skimmers have threads inside the holes, and a copper or PVC threaded fitting screws into these ports. Squirt food coloring just above the holes and see if any of it is pulled down into them. This indicates a leak which may be caused by a poor seal between the skimmer threads and the fitting. If you put your finger into the holes, you should be able to feel where the top of the fitting meets the skimmer threads.Repair any cracks or breaks in the skimmer walls with epoxy putty.Use the silicone sealer to repair areas where the skimmer has pulled away from the pool wall, where the corners are cracked, and in tile cracks. These leaks are the result of a cracked bond beam or shifting soil from water getting into the ground around the skimmer.
Also Check this Link
I hope you got an idea...thank for Using FixYa...
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Fish Logo
309 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
