Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Tv not funtioning.
Red light keeps blinking like someone is pressing the remote or touch buttons and menu and etc keeps popping up..Help me pls..
Power re start
Posted on Jul 19, 2013
Testimonial: "how do you do that?"
  • JenZ Jul 19, 2013
    how do you restart the power?
SOURCE: Samsung ltm1555B - lcd tv blinking on button
I am having the same problem with the blinking orange light
Posted on Aug 31, 2008
mgomolinski
  • 4 Answers
SOURCE: Samsung LN-S4051D Tv Cliking noise only but tv does not come on.
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don't stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I'm getting samples of those and will replace them shortly. After that this piece of **** should last me at least another 2 yrs! It's been working for about a week now w/no problems. Hope this helps.
Posted on Dec 16, 2008
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
  • 22 Answers
SOURCE: my Samsung LCD TV (40A450) 40 inch, when switch
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Posted on Oct 06, 2010
micromatikal
  • 2777 Answers
SOURCE: I have a LN40A330J1D Flat
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. I am quite certain that is what it is, that is exactly what the blinking power light indicates. It is getting enough power through the power supply to light that little indicator light, but it can't power up the TV itself.
This is the most common problem with all LCD tv's unfortunately, and for whatever reason it is very common in Samsung models :(.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Oct 07, 2010
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
I need the codes to have this universal remote to work on a Sony Bravia, can someone help?
Three digit codes are: 002/ 006/ 071/ 128
Four digit codes are: 0128 0013 0002 0071 0380
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 12, 2012 | One For All URC-3021 Remote Control
How do i program a MerchSource touch remote to my emrerson tv
Codes are.
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Direct Code Entry
    Code Search Method
Apr 15, 2012 | Televison & Video
How to unlock the tv with out a remote?
Hello
If you haven't a remote, it is very difficult to unlock the TV. Anyway try these following steps. Sometimes may help you.
Wish you sucess.
Oct 24, 2010 | RCA TruFlat 27F520T 27" TV
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
The sharper image jumbo touch panel remote control, can program every appliance (tv, dvd,etc.) except my directv hd receiver. no codes listed in booklet for the hd receiver, tried the codes for regular...
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Jan 04, 2009 | One For All URC-9910 LCD Remote Control
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
RC24912 - D
1 manually turn on the device (tv, vcr. etc) to be controlled
2.Press and hold the setup button until red indicator stays on, then release the Setup button.
3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912
4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press.
5. press and release the mute button to install the code. Then the light will go off.
Jan 19, 2008 | GE RM24912 Universal Remote Control
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
Henry  Thomas
Henry Thomas
