Question about Scotsman Refrigerators
Water diagnostic code - Scotsman Refrigerators
    Novelist:
  • 187 Answers
I do not have enough of your water diagnostic code, but the normal cause is the dual temperatur probe, if the sensor that is inserted just downstream of the water pump is bad and doesnot sense the temperature change as the water cools the unit senses this as a water pump problem and stops the freeze cycle but shutting down and giving a water code. PS I use to know a guy on the USS George Bancroft before 1980 named DJ White. If you were this guy I still have your ship's plaque if you want it.
Joe Abbey
Posted on Oct 01, 2014
SORRY wrong forum but hope it can still be answered. Quiet Partner 3 dishwasher completes diagnostic perfectly but will not run normal cycle. Inlet valve works as does the float during diagnostic.
Does the water fill during other cycles? How did you confirm the water inlet valve works, through the diagnostic mode or just by applying power? There's a chance it is not providing enough water pressure to trigger the pressure switch (although that would likely cause a diagnostic code).
Oct 15, 2016 | Washing Machines
CODES p0172 AND p2196 AND p0171
Illuminated Check Engine Lamp with Diagnostic Trouble ...
oemdtc.com/.../illuminated-check-engine-lamp-with-diagnostic-trouble-c...
May 11, 2015 - Illuminated Check Engine Lamp with Diagnostic Trouble Codes ...P2196, P2197, P0171, P0172, P0174, P0175 or P162F - 2015 Ford Transit.
Aug 18, 2015 | Cars & Trucks
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    Energy saving devise light blinking and no hot water
    Water heater is not identified.
    Add a comment with information that appears on label on side of tank for possible help.
    You might be talking about Whirlpool energy smart electric.
    The error diagnostic lights flash a code: the code decipher is printed on the diagnostic control box on top of heater.
    Call Whirlpool: you need model number and serial number from label located on side of tank.
    1-877-817-6750
    Open following links for energy-smart resources and typical manual:
    http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
    http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
    Aug 04, 2011 | Whirlpool Water Heaters
    I hav e code H and a code F flashing on my whirlpool front loading washing machine what does that mean. It has stopped in mid cycle.
    it means a water fill error,either the units not getting water or the pressure fill switch in the top right side of the unit isn't detecting water level and shutting off the machine after a preset amount of time,find the diagnostic troubleshooting pamphlet inside the unit and run the diagnostics on the machine and it will tell you what components at fault
    Jan 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite Oasis HE washer error code F2
    The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
    The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
    Diagnostic Test Mode Procedure
    1. Close the door.
    2. Select the DRAIN/SPIN.
    3. Select NO SPIN by pressing the SPIN SELECT button.
    4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
    5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
    6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
    7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
    8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
    Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
    Jan 20, 2010 | Washing Machines
    No hot water
    The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
    This is not a task for the "do it yourselfer"
    Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
    Diagnostic complete
    Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
    C:00 - Door Lock
    C:01 - Flow Meter, Cold Water Solenoid
    C:02 - Dispenser Motor, Dispenser Contacts
    C:03 - Hot Water Inlet Valve
    C:04 - Motor rotates CW at wash speed
    C:05 - Heater & NTC (Heater Sensor)
    C:06 - Drain Pump
    C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
    C:08 - Motor rotates CCW at max. speed.
    If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
    Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Refrigerators Logo
    56 people viewed this question
    Top Scotsman Refrigerators Experts
    t-stat
    Level 1 Expert
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
