Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Refridgerator ice machine rotator rod is not turning
It is making ice but not pushing it through the dispencer
    Problem Solver:
  • 9 Answers
PULL OUT AND MAKE SURE THE ROD/MIXER IS IN THE MOTOR HOUSING,IF ITS SLIPPED OUT YOUR ICE WONT ADVANCE FORWARD...
Posted on Oct 13, 2013
  • 1314 Answers
SOURCE: GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Posted on Jan 15, 2008
rylee_smith
  • 8619 Answers
SOURCE: Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Apr 09, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a GSH22KGPCC model GE side by side. The
You may have a frozen (literally) auger motor. If you warm it up and dry it out, it will run, but it will freeze up again. If this is the case, you will have to replace the auger motor and install a motor sheild over it.
Posted on Jul 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker makes ice,but won
Does your dispenser face look like this part number WR55X10415
If not then we need to look for the correct model number in the photo locations below. I think the control board is shorting out behind this panel.
You can visit my sites below and enter model or part numbers for your refrigerator. Also I will be here to help you get the problem fixed, Thanks Sea Breeze
SITE 2=> http://appliancepartseast.blogspot.com/
SITE 1=> http://servicepartstec.blogspot.com/
Posted on Jul 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: broken ice maker/ water
If your ice maker has parts missing and you can not get the water to fill you don't have too many options I am sorry to say because yours is electronic.(No Replacement Parts) Part number Click Here=>WR30X10093 Point and Click Appliance Repair Sell Genuine OEM replacement parts. Ebay sells parts for less but the are counterfeits. And I'm a little with the angry with them when they claim to have the real thing and you can not even buy wholesale from GE at those prices. I would like someone to test the voltage to the water control valve when someone presses dispense water. If you get 120 volts to the side of the valve that dispenses water and nothing comes out I believe your ice maker and dual water control valve are defective. Part number for your water control valve is Click here=> WR57X10050
I'm very good with your model and its problems so if you need help please let me know. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Feb 09, 2010
THe ice /water dispensor is throwing out ice and water independent of contact from a glass hitting the dispense level, to have it dispence. As a result we have turned of the water and ice control but now...
This is a general answer. The water dispenser paddle makes a switch that then opens a water solenoid valve that dispenses the water. The ice paddle makes a switch that starts an auger in the ice bin to push the ice out. There is either a rod across the bin to detect the height of the ice in the bin or a thermostat that hangs a little way down in the bin. These will open a water valve to fill the evaporator to make more ice if they think the bin is low. Mineral buildup in the water valves is fairly common and can keep them from completely closing. I don't know which light your referring to, but the low ice light should go off when the bin hills. Also, small inline water filters are available in most hardware store to filter water for refrigerator use. I hope this helps.
Dec 15, 2013 | Freezers
I have a maytag refridgerator ice maker wont make ice. Water dispences fine???
check if the compressor has leakage, if not, make sure the gas is at the normal level.
Aug 09, 2011 | Maytag Refrigerators
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
I have an Amanda 22 side by side refridgerator with an ice & water dispenser. The ice machine unit's metal rotating rod continues to rotate and continues to dispense ice cubes, although the ice...
Must be the actuator to the ice dispenser is stuck against the micro switch. Like somebaody had a bad day and slammed my acutator around. No model number given so I guess you gotta go with this MANUAL fer a reference.
Sep 13, 2009 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore refridgerator #25351694102
check for a lock button on dispencer controls
Aug 05, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
