Question about TCL L40FHDM11 40 Inch 1080p LCD HDTV
Red Shadow My 42 inch TCL LCD TV is showing red shadow it seems as if its the video display is out of range. How can i get in the service menu to try to reset the settings or what should i do to remove this problem? Model # L40FHDM11
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Dec 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
How do I attach my dvd to the 42 inch tv to watch a movie? Do I just attached the RGB connections?
An HDMI cable is best however a set of Component cables will also work. The Component (RGB) will also carry a high def image. You will need five cables in all. The Red, Blue, Green for the video and two additional RCA cables for audio (red and white). Color match the inputs to both the DVD and the TV. Select "Video" source from the Input menu of the TV. Confirm this worked.
Jul 01, 2010 | Haier HL42R 42 in. LCD TV
LCD tv screen has a shadow, what is the problem? I have a picture of the shadow on the screen and know where to find parts but have no idea what the problem is. I'm thinking of two areas, the polarized...
The shadow have red or blue in colors mixes?Than ur LCD screeen is damage.If it have a very light shadow,move the tv around to West,East Northwest,Southeast might help.If it have magnetic field.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
TCL L40FHDM11 40 Inch 1080p LCD HDTV Logo
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
Back2life...
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
