Question about Vehicle Parts & Accessories
After it rains..... I'm not sure if its the windshield or the sun roof that's leaking........ After into my car, when I start to drive..... There are water pouring out of the over head console/ with t
    Top Expert:
  • Vehicle Part... Master
  • 21,873 Answers
Since water flows downhill, I would expect it to be the sunroof drain.
Posted on Jul 17, 2013
2006 dodge durango that does not have a sun roof that leaks water on the Head liner and seat belt and floor when it rains or I go thru car wash? What could cause this?
I just Googled a picture.
There is a roof rack type trim on the roof.
Water flows downhill
3 possible sources:
- window trim
- windshield
- roof trim
I would be suspecting the roof trim. Determine how it is attached. Remove it. Clean the roof and all parts of the trim that contect the roof. Apply sealant in appropriate locations. Re- install roof trim.
Test
No leak!
Ta-Da!
Apr 15, 2016 | Dodge Cars & Trucks
2008 mustang water. on passenger floor board when it rains ...help !
Sounds like the windshield is leaking. Run water over the windshield and have someone get inside car and look for the leak. Alternatively take it to a reputable windshield repair shop and have them check it.
Oct 11, 2014 | 2008 Ford Mustang
2004 sebring water leak drivers side only when driving
leaks Where? under the car, in the hot sun? from the top of door driving in the rain? close yr windows. or its condensation from the air conditioning system....both are normal.
Aug 01, 2014 | 2004 Chrysler Sebring
Whenever it rains and the car is not moving nothing leaks, but when I take a left or right turn water starts to leak out of the buttons and sides of the head console GMC Yukon 2004
Just mean water is traveling and most likely pooling up somewhere to ether coming from windshield or sun roof if you have one
Mar 05, 2013 | Cars & Trucks
When it rains, waters gets into the passenger side of my suzuki xl7. Its not leaking from the sun roof. what else could it be?
hi there
if it is not leaking from sun roof the seal around the windshield this happens quite often hope this helps you find the problem thank you and have a great day
Aug 21, 2011 | Suzuki XL7 Cars & Trucks
2002 Xterra SE. The sun roof leaks water when it rains. it leaks around the right front corner of the sun roof, above right sun visor on passenger side. I inspected under the sun roof and I did see...
have the rubber seal around your windshield check by a wind shild installer base on what you explain the sel at that corner is leaking and the water is leaking back into the vehicle
Oct 13, 2009 | 2002 Nissan Xterra
Drivers floorboard is wet after it rains
Got a sun roof. Drain hose came off above headliner
Sep 26, 2009 | 1999 Honda Accord
Rain water leaks from overhead console (No sunroof)
common problem with these roof racks check for loose bolts holding it on also there are inserts pressed into your roof under the roof rack these threaded insrts tend to come loose or get pulled out use silocone sealant around every bolt and insert.
Sep 19, 2009 | 2001 Jeep Grand Cherokee
Water leaking into down A pillar into drivers floor pan
First off, get a second opinion from another windshield replacement company. I've hada couple of windshields removed to reseal and they never broke it taking it out. Before that, wait for a nice day, and hit the windshield with a water hose. Have someone sit inside the truck and watch for a leak. A car wash is good too because they use high pressure water to wash it and high pressure air to dry it. Another piece of advise, make sure your cowl is clean. Open the hood, and look back where the wipers are. If theres a lot of leaves or other debris, that will also cause water to back up and make its way into the truck. Good luck.
May 13, 2009 | 2001 GMC Jimmy
Water leak
sounds like you have a window seal leak.  The only other way water will leak into the car is a leaky heater core or a clogged A/C drain.  Do you have a sun roof that could be leaking?  As they have drains too.
Apr 05, 2009 | 2006 Chevrolet Cobalt
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
