Question about Food Processors
Kitchenaid 5KFPM775 won't turn
My Husband has a Kitchenaid 5KFPM775 and recently the blade will not turn. It has been assembled correctly as it makes a "buurrr" noise when it is switched on but the blades do not turn. Any suggestions?
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Posted on Dec 15, 2008
co7196
  • 3433 Answers
SOURCE: the blade in my massive kitchenaid food processor
fill with hot water, see if that helps. You may end up losing the contents. Were you processing celery? If so, the blade is just bound up with the stringy stuff.. good luck-ned-
Posted on Sep 13, 2009
1800PartsFix
  • 36 Answers
SOURCE: I have an old Braun Food Processor and today while
Best bet would be to send it to a Braun service center. It is possible that the Blade has now fused to the motor shaft. Try Smallappliance.com, they are authorized and have years of experience with Braun and other products. service@smallappliance.com
Posted on Mar 08, 2011
taran_2005
  • 10515 Answers
SOURCE: The blade seems to be frozen - we can't get
Although it may gouge the metal blade material, you need to try working the blade loose with a large pair of slip joint(water pump) pliers, after spraying WD-40 on the shaft and letting it soak for a couple of hours.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 29, 2011
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
My kitchenaid processor is not working
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Unit assembled, lights are on (pulse, on) nothing happens
Jul 19, 2009 | KitchenAid KFP740 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
I have the unit plugged in and the ingredients in the bowl, but it will not pulse...what am i doing wrong?
I am assuming that the unit is not getting any power whatsoever and this is not isolated solely to the pulse function not working.
May 10, 2009 | KitchenAid KFP740 Food Processor
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
Have trouble getting it to start
Mar 04, 2009 | KitchenAid KFC3300 Mini Chopper 3 Cups...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Food Processors Logo
71 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
