Question about Mtd 22" Yard Machine Push Mower
MOWER WON'T START
I HAVE CHANGED THE SPARK PLUG,AIR FILTER OIL,GAS tHE CABLE THAT GOES TO THE LEVER THAT YOU PULL WHEN STARTING THE MOWER SEEMS TO BE WORKING.BUT MOWER WON'T START. iF I MESS WITH THE LEVER IT WILL START BUT QUITS RIGHT AWAY
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Sounds like you need to drop the bowl on your carburetor and clean the Jet.
Take the 1/2" bolt out of the bottom of the Carburetor Bowl. Look at it. It has two holes close to the Bolt Head. 1 small hole down the center of this hollow bolt and possibly a real tiny hole at the end of the bolt where the Threads stop. Make sure they are cleaned out and not clogged. screw it back in and see if that solves teh problem. Use a spray can of Carburetor cleaner and a small wire to clean the Jet holes
Posted on Jul 21, 2013
5 Suggested Answers
eugbug
  • 479 Answers
SOURCE: I have a MTD push mower that won't start every
Have a look at these tips for troubleshooting starting problems with lawnmowers:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Hope this helps!
Posted on May 14, 2011
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
smjdragonfly
  • 79 Answers
SOURCE: have Bolens series 080 22
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms or gaskets and screens on some, tiny jets and such that are inside the little "bulb" or bowl, that can usually be taken off with a 10mm wrench. They also have little fiber gaskets and a bowl gasket or o-ring that must be in great condition with no trash. Clean off with starter fluid or carburetor cleaner.
Posted on Jun 18, 2009
rycgl
  • 1545 Answers
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Posted on Jun 05, 2011
The manual start rope will not pull. Seems to be stuck.mower has been garage kept,no gas left in mower over the winter. Air filter and oil has been changed. Lost!!
Possible that the motor has frozen. See if blade can be manually turned after disconnecting the spark plug;using a long breaker bar, turn the bolt on the blade to see if you can unfreeze it if blade is stuck.. Make sure that you have oil in the crankcase.
Mar 29, 2017 | Garden
Mower starts easily, but runs 10 seconds and quits.
Carburetor needs to be cleaned; main jet is clogged with debris, dirt, whatever.
Jun 23, 2015 | Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
47 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
