Question about New Ray Lockheed C130 Hercules Military Uscg Aircraft Airplane
Hydraulic fluid used in c-130j aircraft - New Ray Lockheed C130 Hercules Military Uscg Aircraft Airplane
What type of hydraulic fulid to use in ford 600 tractor
Get a top quality non-water based fluid and you will be OK. I looked around on the web and could not find any recommended fluid for the 600. Make sure you use real hydraulic fluid not engine oil. Hydraulic fluid has more anti-foaming and wear agents in the fluid. A real tractor shop will certainly help you with your purchase.
Dec 22, 2017 | Ford Garden
Why can't a DC-10 fly without a flight engineer?
no but the flight engineer moniters fuel and electrical use hydraulic levels and apu operation
Jan 04, 2017 | Aircrafts
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
Where to find skematics of antique steadman aircraft?
Do you mean Stearman? Made by Boeing Aircraft the Stearman was made for the US Army, Navy and Air force and has a number of variants. Almost all by a few are now in private hands and the most common variant is the Stearman Model 75. You didn't specify the schematic you require, either. Electric, Fuel, Hydraulic or whatever. When asking questions you need to be as accurate and a specific as possible. Also be careful of automatic spell checkers that will change Stearman for Steadman without you even knowing!!
_________
Aug 16, 2015 | Sport & Outdoor - Others
How does a pneumatic system work on an aircraft piston engine?
The piston engine is the power plant. It generates thrust by turning the propeller, electrical power through the generator, hydraulic power with engine oil and/or a hydraulic system. It also sometimes has a vacuum pump in the form of a sliding vane pump to operate the mechanical gyros instruments. On a piston engine there is no "bleed air" supply. For the cabin pressure pneumatic system, piston aircraft, take compressed air from the compressor side of the turbocharger (or supercharger old airplanes) and routed into the cabin as long as the engine is running. The outflow valve which regulates how much air is let out of the cabin is used to maintain the desired cabin pressure. The cabin outflow valve is controlled by a cabin pressure controller where the pilot sets the cabin pressure and climb or descent rates. This is the only pneumatic system I can think of other than "de-icing boots" on the wing leading edge that are pneumatically operated.
A "receiver" is usually associated with a receiver/dryer in an air conditioning system.
Jun 09, 2014 | Sport & Outdoor - Others
My clutch is not angaging need to see how can i bleed
Hydraulic Clutch System BLEEDING The clutch system can be bled using a pressure bleeder. Follow the instructions that come with the pressure bleeder for the proper pressure bleeding procedure. The maximum line pressure while pressure bleeding must not exceed 36 psi (248 kPa). NOTE: To bleed a clutch manually requires the assistance of a second person, a section of hose that is compatible with brake fluid (preferably clear) and fits the slave cylinder bleed screw snugly and a container to catch the fluid that is bled through the system. As brake hydraulic fluid easily absorbs moisture, always use fresh fluid when bleeding a hydraulic system.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. To bleed the system perform the following:
    1. Top off the hydraulic fluid reservoir using a fluid that meets the standards of the vehicle's hydraulic system.
    2. Open the clutch slave cylinder bleed screw and press the clutch pedal to the floor and hold the pedal down.
    3. Close the clutch slave cylinder bleed screw.
    4. Release the clutch pedal.
    5. Check the hydraulic fluid level and top off as necessary.
  3. Repeat the above steps until the discharged fluid is clean and no air bubbles appear during the bleeding process.
Aug 03, 2010 | 1998 Audi A4
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Sep 07, 2009 | The Times Case Corporation Tractors...
Where to buy hydraulic fluid
if dont find hydraulic fluid,you can also uses automatic transm. fluid (DIII),this not cause any problem
Apr 07, 2009 | 2000 Lexus LX470
Hydraulic clutch problems
i have a ktm 125 wich all ktms have hydraulic cluthcs and i have the same problem as all these fellas even when im riding it just sucks right down all the fluid reply to me on X-KTMrida-X@hotmail.com ok thanks fellas
Jul 08, 2008 | 1997 Chevrolet S-10 Pickup
New Ray Lockheed C130 Hercules Military Uscg Aircraft Airplane Logo
29 people viewed this question
Top New Ray Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a New Ray Toy Expert? Answer questions, earn points and help others
