Question about Home Security
Replace tail light bulb contour 97 - Home Security
eitan
  • 291 Answers
SOURCE: replace tail light bulb
The process for changing the tail light bulbs for a 2002 New Beetle in my case a TDI is relatively simple. To remove the lense and gain access to the bulbs you first need to release the lense holder from inside the trunk by completely unscrewing the large plastic wing nut that is under a round plastic panel that's located almost directly behind the rear brake light lense. To gain access to the plastic wing nut remove the round panel by gently prying it off. After this is done you release the lense by using something flat like a dinner table knife to pry and release the clip that holds the lense in place. Locating the clip: The rear fender has two seams that end at the light lense, the inboard seam (the one closest to the hatch)is where you want to insert the table knife to pry the metal clip that holds the lens in place. Gently and carefully insert the knife blade directly at the seam and pry upward to release the lense. Once the clip releases pull the lens the rest of the way and remove the bulbs by turning the bulb holder sockets couter-clockwise. After this is done remove bulbs by slightly pushing down on the bulb and turning it counter-clockwise. The reinstall is reverse of the removal the procedure.When re-installing take care to clock the lense where the metal clip and the lense protrusions end up in the same position as before. Note: you may need to assist sliding the lens retaining clip in with the knife when reinstalling! Good luck
Posted on May 15, 2008
eitan
  • 291 Answers
1. open tailgate. 2. remove corner floor piece by lifting. 3. remove corner side panel. pull out from tab on bottom. 4. remove two hex bolts(#10) to release light housing. they look like large allen wrenches. 5. replace bulb(s) and refasten again.
emissionwiz
  • 76630 Answers
SOURCE: Need to replace tail light bulb on 1996 Buick Century
Inside the trunk, under the carpet behind the tail lights will be a whole bunch of small plastic nuts, running from one side of the car to the other. Take all of these plastic nuts off, and the whole tail light assembly will come off in one large piece. Find the bulb you need to replace, and reassemble
Posted on Apr 06, 2009
  • 490 Answers
SOURCE: 97 CAMRY TAIL LIGHTS PROBLEM
You are right you do have a short,but it's easy to fix at the same time it is expensive. In your trunk area you will find a bulb out relay it can be either in the right corner or left corner panel in the trunk area,if not there if may be under the rear deck of the trunk(under the rear window inside the trunk) It might be yellow brown or green.One fron the junk yard will work just as good as a new one.If you are skillful you can open it and solder the burned circuit,but you have to know what you are doing.You also neet to find out if you had a bad bulb that shorted so you can rest knowing that what caused it to burn out in the frist place is fixed.
Posted on Jul 23, 2009
c17hydro
  • 2984 Answers
SOURCE: Hi, How do I replace the tail light bulbs in my
Sedans
  1. Remove the screw(s) and wing nut retainers at the rear of the luggage compartment and push the trim away from the back of the light.
  2. Remove the wing nuts retaining the light assembly to the vehicle and the retaining nut from either side of the luggage compartment and pull the light body assembly from the vehicle.
  3. Turn the bulb socket(s) counterclockwise to the stop and remove the socket(s) from the light assembly. Remove the bulb(s) from the socket(s).
  4. Installation is the reverse of the removal procedure.
Push the trim away from the back of the light—1992-98 Crown Victoria
The rear tailamp assembly is held by various fasteners
Remove the wing nuts retaining the light assembly to the lower back panel—1992-98 Crown Victoria
Remove the nut retaining the light assembly from the side of the luggage compartment
Pull the light assembly away from the vehicle—1992-98 Crown Victoria
Posted on Oct 12, 2009
Testimonial: "I was thinking I would get to the bulbs from inside the trunk. This info makes perfect sense. Thanks"
96 contour. left tail light, 1 and 2nd break light are out.
Everything works, more or less, so you know that the switches and fuses are good. That means that you've got either bulb problems or power/ground problems. First, try swapping the bulbs around to see if the "bad" lights will work with the known "good" bulbs in them. If so, you just need to replace some bulbs. If not, check the sockets inside and out for corrosion, clean them (wire brush, steel wool, sandpaper, etc.) if necessary, and use a voltmeter or automotive tester to make sure that you have power and ground to each socket. The fast flash on the turn signal is just an indicator that a bulb is out.
Bill B
Apr 28, 2010 | 1996 Ford Contour
I am trying to replace the brake light bulb on 97
Open the trunk and remove the fabric insert located by the tail light. There should be 2 plastic nuts toward the center-most part, one above the other about 6 inches apart (One above the other). Then on the quarter panel side (where the light comes to a point on the outside) there should be just one. Making a total of three nuts to remove it. On the plug there should be a small plastic red clip. Slide it aside and squeeze the tab to remove the plug. After you pull the light out you will see two silver dollar sized circles that hold the light bulb in. Twist this to remove the light bulb. There's also a third smaller one for the smaller bulb.
Feb 24, 2010 | 1997 Plymouth Breeze
Rear tail and brake lights out 97 Jetta
I believe this car has a bulb with two fillaments for side and brake lights, it is unlikely that they are both burnt out at the same time but possible. It is more likely that the bulb holder or a ground connection is rusted or loose. The fuse generally covers all rear lights.
Jan 02, 2010 | 1997 Volkswagen Jetta
My tail don't work. I check my fuses & change my light bub my tail lights just want come on.
check that the screws holding the bulb housing are earthing against the body work check for rust and clean
Nov 14, 2009 | 1996 Ford Contour
How do you change the turning signal on ford contour sport?
This is for the 95-97 Contour. 98+ are different, because the light housing changed completely.
1. Open the hood.
2. In each front corner of the hood, there is a torx bolt, head about the size of a nickel. Removing this one bolt allows you to remove the corner marker/turn signal housing.
3. Once the housing is free, you have access to the back of the bulb holder. If I recall correctly, it's a half-twist to remove, but I'm not sure. Could just be barbed clips, or something. Anyway, from here should be no problem to figure out how to remove and replace the bulb.
4. Replace corner marker/turn signal housing, and re-install torx bolt. That's it!
Oct 11, 2009 | 1997 Ford Contour
My 97 plymouth breeze's right rear tail light went out, I changed two bulbs. Now my right turn signal clicks at twice it's normal rate. Is it most likely Bulbs, fuse, or a pesky short.
It is most likely another faulty bulb in the turn signal circuit.
Ensure the indicator bulbs are replaced with the correct (specified) wattage rating.
Check you haven't dislodged or otherwise lost the ground connection to the rear tail light bulb sockets.
Oct 08, 2009 | 1997 Plymouth Breeze
How to replace 1998 Ford Contour headlights (with diagram)
Step 1
Remove your Contour's front grille. You can do this by raising the hood and removing two screws that are located on top of the grille.
Step 2 Remove the headlight assembly. The headlight assembly is held into the front of your Contour by three screws. Two screws will be located on top of the assembly, and one on the bottom.
Step 3 Replace the headlight assembly, if necessary. If you are only changing individual bulbs, make sure you replace the correct bulbs. Each assembly holds three light bulbs, including the bright, dim and turn signal bulbs.
Step4 Replace the headlight assembly and reattach the three screws to hold it in place.
Step5 Replace the front grille of your Contour and the two screws that hold it onto the front of the car.
  • It is usually a good idea to replace bulbs together (in pairs). This will allow the bulbs to wear at the same rate.
  • If you choose to replace only the individual light bulbs, do not touch the new light bulbs. The contact of your skin on the bulbs will cause the light bulbs to burn out much sooner.
Let me know if you have any further questions.
Benjamin
Apr 26, 2009 | 1998 Ford Contour
Breeze's brake light went out. changed bulb, now whole tail light won't work.
sounds like you put the wrong bulb in, that will make it blink fast. re check
Apr 18, 2009 | Plymouth Breeze Cars & Trucks
I have a 97 Honda Accord. We just replaced the lens since it was broken, the light stilled worked, however since we changed the lens, it works except we we are actually pressing on the brake pedal. Whats...
The tail light works but not the brake light? The bulb is burned out this is a two phase, or function tail light one for running lights the other brighter one is brake lights. Simply replace the bulb and this SHOULD fix it. Good Luck
Nov 28, 2008 | Honda Accord Cars & Trucks
Home Security Logo
35 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
