Question about Vehicle Parts & Accessories
My passenger side door open with the fob.... But it won't open from the outside...... It will open from inside
Have to remove the inner door panel
to find the problem with the outer handle
Posted on Jul 20, 2013
  • Angelia Adams
    Angelia Adams Jul 20, 2013
    I sure will Thank u
Why doesnt my G37x sedan front doors open?
2009 Door Problems - MyG37
www.myg37.com/forums/g37-sedan/253409-2009-door-problems.html
Dec 6, 2013 - 2009 Door Problems G37 Sedan. ... My problem is that my front driver side door will not open up from the inside or outside. My FOB key ... door wouldn't shut....now it won't open
Mar 5, 2015
Help! my windows roll down when i open the door!
Apr 10, 2013
Rattle in drivers side front door
Dec 11, 2010
Window Reset
Jul 28, 2008
More results from www.myg37.com
Driver's side door won't open!? - G35Driver
g35driver.com/...sedan-v36.../371407-driver-s-side-door-won-t-open.ht...
Mar 24, 2011 - I went to get in my car today and my driver's side door won't open - from inside or out. There's. ... The manual locker inside doesn't work. Problem with driver side door locking (and unlocking)
May 3, 2011
Dome light issues
Jul 3, 2010
More results from g35driver.com
Drivers door would not open - Nissan Forum ' Nissan Forums
forums.nicoclub.com/drivers-door-would-not-open-t466851.html
Dec 11, 2009 - My wife went around to the drivers side and used her key to see if she
Jan 27, 2016 | Cars & Trucks
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Passenger side door won't open
inside and outside
key and fob both dead?
Mar 06, 2015 | 2011 Jeep Compass
2001 BMW X5 Unlocked driver door wont open from inside or outside
handles may be in good condition but the lever on the latch itself may have came loose. your mostlikley looking at dismantelling the apolsery with the door closed to rectify it.
Apr 21, 2013 | 2001 BMW X5 3.0i
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
First problem started when the passenger door didn't open from outside. Now when you lock the car, the passenger door won't lock.
Sounds like the locking mechanism in the passenger door may need lubrication. You could also have a wiring issue and/or the actuator solenoid on that door could be bad. I'm assuming you are using the keyless locking fob. What happens when you push the door locking button on the driver's side door or the locking button on the passenger door itself? If these work as they should and with not hesitation then you likely have some other problem in the locking system.
Jun 11, 2011 | Volkswagen Golf Cars & Trucks
Central locking issue on my Land Rover Discovery II 2003
Does it open from the outside once you have manually opened it from the inside.
Jul 08, 2009 | 2003 Land Rover Discovery
Range Rover Passenger Door Will Not Open
I have a 2002 land rover discovery and my passenger front door won't unlock with the interior lock button on the dash or with the key fob. The only way to unlock the door is to pull the handle on the inside of the door. Is the actuator bad?
Please help
Rover2163
Jun 18, 2009 | 1998 Land Rover Range Rover
Driver's door lock will not open by key or electronic fob
I was able to determine if you move the inside door handle toward the front of the car, then you could remove the door panel. However, it takes a little force to pot out the plastic clips, but if you work around the outside by appling pressure with a thin tool, such as a putty knife it will pot out.
My problem was a small yellow plastic part that connects the outside and inside door handle rods was broken.
So I plan to replace the part and see if that fixes the provlem. If so I can save over $340 dealer repair costs.
Nov 12, 2008 | 1997 Toyota 4Runner
Vehicle Parts & Accessories Logo
107 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
