Question about Electronics - Others
Welder kende HiI've got kende inverter ceo-1000s about 3yesrs old,hardly used.Last time Iused it it was working fine.Kept back in box,took it out last week,light came on, fan was turning but nothing else was working,is there a way to fix this.Many thanks. Alwyn
rockitman187
  • 2559 Answers
SOURCE: No power output from my vector 1000w inverter.
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Posted on Jan 26, 2009
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Posted on Feb 01, 2009
protek480
  • 1714 Answers
SOURCE: Solar system, 2 SW5548 inverters
How are the batteries for that inverter? Have you got a dead battery in the loop?
Posted on Jul 03, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium - Cold coffee although producing steam.
The only thing that comes to mind is one of the thermostats on the boiler.
Posted on Jul 22, 2009
beachbum069
SOURCE: I have a sony kdf-50e2000 i replace the lamp last
there is a micro switch on the bottom right where the blub plugs in, you need to gently pull it back out...WITH THE SET UNPLUGED
Posted on Nov 25, 2009
What is the tip thread size of kende 150 mig welder . It's not standard euro torch
are you sure it's not a 1/4" 28 national fine? check the tip by threading it in a thread die
Apr 27, 2016 | Welding Tools
We were given the TB110MW9 Digital TV DTV Converter Box for Analog TV but with no remote . we do have other remotes we've kept from our last box that also died.would we be able to use this re
I thought that model number looked familiar. The answer is a qualified yes. If you have a Magnavox or a Philips remote it should work. If you have a universal remote try to search for a code that will control the box.
Nov 29, 2012 | Magnavox TB110MW9 DTV Digital to Analog...
How do I oil an old Simplex school clock?
Many of the old Simplex clocks used what is called a synchron motor. They are ending their useful life when they start making noise. You can extend the life a bit by light spraying WD-40 into them. ( under the cover ) Best, since they are usually held in with just 2 screws is to order a new one. They can be found online by Googling the information that is printed on the round motor cap.
Apr 02, 2017 | Locks & Locksmithing
1972 olds 98 455ci starts and runs fine when its cold but once i've driven it for awhile it starts sputtering like its running out of gas
sounds like a vapor lock. older cars needed a set of points . they kept firing times in sync with fuel delivery , valves opening/closing try that.
Jul 29, 2012 | 1972 Oldsmobile 98
Head unit has power but the buttons and remote do not work.
May be the detachable panel buttons are stuck. Call customer relations.
Feb 26, 2012 | JVC KD-HDR50 Car CD/ MP3 Player
Kende 150R gas/nogas mig welder
Hi I have the same welder with the same problem, I've striped it down and found that there are a few teeth missing on the gears that run the wire feed,
Had no luck finding any replacement parts though
Sep 05, 2010 | Troy MIG100 90-Amp. Wire Feed Welder
Electronics - Others Logo
65 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
