Question about Dell Vostro 320 Desktop Computer
Wireless keyboard not found
Have moved Dell Vostro from one house to another. Worked fine at previous location. When plugged in at a new location, message on screen says, Keyboard Not Found. Have new batteries in keyboard.
jeff_olymp24
  • 84 Answers
SOURCE: Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Posted on Oct 12, 2008
yooperbud
  • 8637 Answers
SOURCE: bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 23, 2009
  • 27 Answers
SOURCE: Dell External keyboard arrow keys not working.
wat?
Posted on Feb 09, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: Dell C521 Will boot to User login But cannot use mouse or keyboar
did you try starting the computer with both mouse and key board allready pluged in so it can recanize that there pluged in,no any mouse and key board will work also did you switch the 2 to make sure you did'nt have them pluged in the others spot?
Posted on Mar 10, 2009
ArcAiN6
  • 152 Answers
SOURCE: Dell Bluetooth Wireless Keyboard doesn't work
check the device for a " reset " button, they are usually located on the bottom of the device, if this does not work, you may need to contact dell directly and discuss the problem further.
Posted on Jun 21, 2009
Logik customer service
First, locate the battery compartment and change the battery. This solves most problems of this type. Does it have a USB dongle? to plug into a usb port? try changing the port
Sep 09, 2014 | Case Logic Wireless Multimedia Keyboard
Where is the power switch on dell m756c?
It should be on the underside of the keyboard with a sync button also the sync to the receiver.
Apr 27, 2014 | Wireless Keyboards M756c - Keyboard, 104,...
I have a Dell Vostro and the wireless mouse justed stopped working. The funny thing is my Mom has the same computer and she called me to tell me hers wasn't working and that's how I found out niether was...
one of two things, the wireless trasmitter boxes could be faulty or they have been zapped with rf from a radio transmitter, { Iam a ham and have zapped mine when transmitting, }just unplug the mouse usb lead then plug in and it should restart working
Jul 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
Dell wireless adapter for Windows XP Media Centre can not find keyboard
The first thing to do when you have a hardware problem is always to go to Device Manager :Start>My Computor{left klick on My Computor}>Properties>Hardware>Device Manager.In the drop down,find your device that is giving you problems.Double klick on the device and see what Windows says about it ,whether it needs drivers or has a physical problem.Your USB adaptor seem to be working OK since it is oscillating ,meaning that it is searching for the Keyboard transmission to lock on.This means that you have loaded the correct driver software for the usb device.I suspect that your problem is with the Keyboard power-make sure you have installed the batteries correctly{polarity check}When all is working properly,you should find the keyboard listed under Keyboards in Device Manager.Double klick on it to see if it is working properly.Your USB device should appear under USB Controllers.Regards
Jun 07, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Vostro 320 Desktop Computer Logo
62 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
