Question about Garden
How to replace the CDI module on a Honda 4518 Lawn Tractor
5 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: craftsman lawn tractor sudden no fire repiaced
Check for a sheared flywheel key. One way to check is to move the piston to top dead center and look at the position of the magnets on the stator in relation to the poles on the magneto. If the positions aren't very close at TDC, the flywheel key is most likely sheared, which is why you are not getting spark. Did the tractor blades hit anything hard lately when mowing? The key is made of soft metal so that if something like that happens, it will fail before the crankshaft gets bent or to prevent heavier damage. Anyway, you might want to check it out. Hope this helped and best wishes.
Posted on Aug 06, 2009
canbruce75
  • 1776 Answers
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
Posted on Aug 31, 2009
wadembly
  • 489 Answers
SOURCE: 16 hp lawn tractor won't start; replaced battery
starter cylinoid is bad i almost bet
Posted on Jun 27, 2010
Testimonial: "Fixed it in now time. Thanks for your help."
  • 8 Answers
SOURCE: Husqvarna Riding Lawn Mower High engine rpm after warm up
pour liter fluid all over the machine then throw a lit match into it
Posted on Aug 29, 2012
Honda 4518 Is very hard to stat it may start or may not
many possibilities, spark plug bad is easiest to check first
Jun 11, 2017 | Honda Cars & Trucks
Hello, I have a 1997 Honda cbr900rr I have a 1998-99 cdi box in garage anyone know if it will work? Spent hrs online researching and nothing convincing
Hi, Trevor your 97 CDI and the 98-99 CDI are 2 different part numbers that being said they appear to be plug and play pretty sure you won't hurt anything, however, some systems may not function properly for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1996 1998 Honda CBR900RR Fireblade Service Manual Moto Data Project
http://www.partsfish.com/oemparts/p/honda/30410-mas-l01/module-ignition-control-cdi
Honda CBR900RR Owner Manual
Jun 26, 2016 | Motorcycles
I need to buy a new CDI unit for my 2012 Honda Rincon TRX680F. Who can help me??
Hi, Petro Honda no longer makes that part it has been upgraded to part number 38770-HN8-B41 which is very pricey for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://www.partsfish.com/oemparts/p/honda/38770-hn8-b41/pgm-fi-unit
Honda 38770 HN8 B41 PGM FI UNIT
Honda OEM ECM PCM CDI Module TRX680FA Rincon 2006 2016 38770 HN8 B41 SAVE
Rincon 680 service manual repair 2006 2016 TRX680 Download Manuals...
Apr 07, 2016 | Honda Motorcycles
Problems with rpm above 5500
sticky gel coming from CDI box indicates CDI failure. Sticky gel is the insulating material in the module that is melting and leaking out.
Mar 05, 2014 | 2004 Honda CRF 230 F
Aug 29, 2012 | Husqvarna Garden
My 3204 quits running when it gets hot.
hi there
n9ove64
sounds like it may be a ignition unit going o/c when hot
will it restart when unit has cooled down ?
pay to check tank breather for blockage and check carb main jet for debris partial obstruction
before replacing coil
here is web site for parts
http://www.partstree.com/parts/?lc=cub_cadet&mn=3204+Tractor
go to ignition/ electrical parts section
part number for coil
Cub Cadet KH-24-584-45-S (replaces KH-24-584-01)
Module, Ignition
cheers pauly46
dont forget the thumbs rating
Jun 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Eng. breaks down when hot like a cyl cuts out. Could this be a coil module breaking down when hot . The bike other then this runs fine
You need need to check the pulsar pick up ( like points for a cdi style ignition) , the coils,and the spark plug caps. If any of these are bad replace them. If all test good then your problem is a bad cdi box.
Jun 01, 2010 | 1984 Honda VT 500 C Shadow
I have a honda riding lawn mower h4518h and i am not getting power to the ignition coil
check your safety fri st, be careful. remove the ground wire from your coil, unplug from spark plug. check your spark if no spark than more likely you have a bad coil. lite me know. good luck
Sep 18, 2009 | Garden
Honda lawn tractor
There are very few, if any, grease points in the steering of any lawn tractor. Since I have no idea what model tractor you have, the best I can tell you is look for grease fittings on the main pivot points on the outer ends of the front axle and on the inside of the front wheels. You will only find 1 or 2 for each side.
If you are experiencing difficulty steering, the primary cause is improper inflation of the front tires. Maintain them at 14 PSI and you should find that it steers a lot easier
Sep 17, 2009 | Garden
My 2004 Honda Shadow will not start. I have changed the spark plugs, wires, ingnition coils and now I'm left with the CDI module. The bike turns over but no spark. Is there a way to test it before I buy a...
I would get a test light and check if i had power to my coil and to my cdi module .You more than likely lost powerto one of them .those cdi last for every. check your switch make sure you got power there to. Hope this help
Feb 21, 2009 | 1989 Honda VT 1100 C Shadow
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
