Question about Garden
I have a troy built lawn mower model n- 13aj609g766 , my question is how do i remove steering wheel gear at the bottom of shaft
    Problem Solver:
  • 19 Answers
Unscrew the nut that holds it on then use a gear puller to remove.
Posted on Jul 23, 2013
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
  • 548 Answers
SOURCE: I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
Posted on May 30, 2010
  • 1383 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
  • 15 Answers
SOURCE: oil drain plug
Drain plug is not necessary. Remove the dipstick and tip the mower to the side the dipstick is on and use the dipstick tube as a drain.
Posted on Apr 23, 2009
Steering skips
Three things need to be checked. The steering shaft for play, the pinion gear on the end of the steering shaft and your stationary gear at the bottom. Raise the hood, turn the wheel back and forth so you can see where the play is coming from.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering gear slips
You have the steering shaft the pinion gear on the end of the shaft and the stationary gear at the bottom on the frame. Either the gears are worn out or the steering shaft has too much play in it causing the gears to slip.
Troy Bilt riding Lawn Mower will not steer
at the bottom of the shaft there is a plastic union that keeps the gear against the other gear they crack and then the steering jumps on the gear
Jun 02, 2012 | Garden
Steering wheel gear is stripped
Please for the love of god tell me you have an answer to this, same problem, sooo angry, hit me up at reid72@aol.com pleeeesee
Jul 15, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
