Question about Hampton Bay Indoor Ceiling Fans: Ceiling Fan. Campbell 52 in. Matte
Noisy fan Making noise on med & fast speed, no wobbles, no squeaks. Is there a place to oil?
picatudo
  • 239 Answers
SOURCE: noisey fan
use WD-40 w/ straw spray every hole you can find
Posted on Jan 04, 2009
  • 14 Answers
SOURCE: Fan making a scraping noise
Hi have a look while fan is turned off and see if it is rubbing around sides. If a fan is unbalanced it will rub on one side. Get a ruler and measure from the roof that all blades are the same height gently bend so they are all the same distance from the roof. I dont think you can tighten the fan as it's on a spindle. If it was tight it would not spin Hope this info helps you. Best Regards Alex
Posted on Aug 07, 2009
  • 3 Answers
SOURCE: New fan with downrod wobbles when on high speed
Measure from the same spot on the ceiling to the outer most tip of each blade (by rotating to the tape). The distance should be the same, if not check fan blade screws for tightness. You might have to bend the fan blade brackets a little to get the same measurements, if the screws are all tight. If all this lokks good, you might to use a balancing kit...just follow the instructions...it's not too bad to do
Posted on Feb 19, 2010
SOURCE: Fan is wobbling and noisy--cannot figure how to
I have a number of ceiling fans and its usally wise to just check that each blade as all the washes and fixing. As leaving just a washer out can alter the whight and balance.Some noise is to be exspected till they bed in so to speak unless they wobble really bad
Posted on Sep 29, 2010
MN_Jack76
  • 45 Answers
SOURCE: The fan controller will not
Greetings, UC7067RC tells me you have a "flat pack" receiver mounted in the ceiling fan canopy up at the ceiling. They are know to fail. They actually are fairly complex internally and have an internal capacitor. Things that will shorten the lifespan are: If you have a switch in the room that supplies power to the fan make sure it is a simple on/off switch and not a dimmer switch. A dimmer switch will kill it even if the dimmer is all the way up. Another is "dirty" power where you live. Surges/Brown outs. Lastly moisture will kill them. You can find replacements at www.FanManLighting.com
Posted on May 22, 2015
Fan in nissan pixo 2009 making noises on number 1 any reason why please
The fan bushing are wearing out,, at low speed it just wobbles around, when you speed up, it "self-centers" and stops making noise... won't be long before it starts making noise on all speeds.. just prepare for replacement.
Jun 06, 2017 | Nissan Cars & Trucks
P0495 & p0128
I am thinking you are on the right track. A noisy, wobbly fan has to be replaced and replacing the thermostat could reduce the fan speed as the problems are interrelated.
Nov 15, 2013 | 2005 Chevrolet TrailBlazer
Manual for aHAMPTON BAY ceiling fan campbell
Fan is a little noisy on med or full speed, is there a place to oil it? The fan is level & doesn't wobble.
Apr 02, 2013 | Hampton Bay Dryers
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
4.9 litre noisy, wobbling pulley (between fan and engine)
Turn the motor off and move the pulley by hand, if theres alot of slop in it, change out the water pump.
Nov 28, 2009 | 1988 Ford F 150
Zt desktop rear fan is very noisy upon startup. usually will quiet down after a while or with a smack. Have already cleaned all fans. Sound appears to come from the fan in the very back.
depends on how much use the fan has had in its life, ive got a new pc and the 120mm fan supplied in the rear is not the top of the range and is already making a noise after only a few months of service life. just bite the bullet and buy a new one, you get what you pay for in terms of fans..go for a ball-raced one, not a sintered bronze oiled for life bearing,the fan impellers only need to be slightly out of balance at high speed and they will wear the bearings very fast indeed. i run rc electric planes powered by very fast fans ( 15000-35000 rpm ) and it realy shows on them...good luck & buy a new one :)
Oct 14, 2009 | Computers & Internet
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
The air conditioner is making a squeaking noise and blowing cold air but not full strength
The squeaking noise is probably a bad or dry bearing in the fan motor, causing it to run slow or not at correct speed. Sometimes there are oilers on the motor that you can try to oil but the motor really needs to be replaced.
Aug 06, 2009 | Heating & Cooling
Wobbly Fan----Nutone Whispaire WA6500
Definetly need a new blade
#K7458-000 Boan/nutone part number
Dec 09, 2008 | Broan-NuTone Intermediate Whispaire ...
Fan motor noise
Does the fan seem to wobble when it is operating? If so, the fan blades may be out of balance. You can purchase self-adhesive weights to stick on the top of the blades to get them balanced properly. It is a trial-and error process, but it is the easiest and most cost-effective way of reducing fan noise. Other possible causes might be: the fan is loose in its mounting, or the mounting itself is loose .A wire inside the fan motor may be rubbing against some moving part. Also, the fan unit may not be properly grounded, or wired with reverse polarity., causing a 60 cycle "hum".
Aug 05, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Indoor Ceiling Fans: Ceiling Fan. Campbell 52 in. Matte Logo
76 people viewed this question
Top Hampton Bay Photography Experts
Tony
Are you a Hampton Bay Photography Expert? Answer questions, earn points and help others
