Question about Fedders Appliance Air Conditioner In-Window
How many amps does my AC use?
I just bought an RV with an old Fedders Air conditioner. I want to get a generator so that I can run it, but I nee to know how many amps it uses before I can do that. All I know is that it's capacity is 7500 an hour. I also have the model number but cannot seem to find anyone that I can ask about the product. Maybe you can help. My model number is A1R08F2B
SOURCE: Parts for Fedders Portable Air conditioner model # SFPEB08F2A
there are two separate solid plastic pieces between the hose and the body of the unit
i have a hose but I am about to donate the unit
Posted on Jul 20, 2008
  • 10865 Answers
SOURCE: what is the air exchanger (open or closed) switch for?
The air exchanger is there to give you the option of adding fresh outdoor air [open] or recirculate the air in the room [closed].
Posted on Jun 04, 2009
  • 34 Answers
SOURCE: can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
bobicehouse
  • 1524 Answers
SOURCE: I have a Fedders Air conditioner model #A3X05F2A.
5,000 btu's
To calculate LxWxHx18 divide by 5
Posted on Jun 02, 2010
  • 17 Answers
SOURCE: fedders air conditioning model a3t12f2ag
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Posted on Jun 18, 2010
Dometer 3105457. how big of generator for the air
If it is a normal AC for RV then I would suggest something over 4000 watts, the AC's have a very high start amps.
You would really need to know how many amps the unit draws or is rated to draw when looking for a generator. Too small of a generator and it won't work, plus you could damage the generator and the AC unit. I would call an RV store and ask them as that is something simple for them to answer.
600315 336 Manuals
Jun 17, 2014 | Dometic 3105457.000 Duo-Therm Penguin RV...
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
My Fedders AC in my 2003 Roadtrek runs but doesn't blow cold air. Can't find valve in order to recharge it. Can you tell me where it is?
Window Air Conditioner are sealed at the factory,
no service valves & you can not buy R22 without
a licence
If you had to add refrigerant,common sense would
say you have a leak
Seldom repair that type of unit
It can be repaired sometimes, but usually they are
20 years old & you get a new one
Jul 16, 2011 | Fedders Q Chassis AEQ08F2E Air Conditioner
I have a 1996 Alegro bus with dual ac. I was running on generator on;y but had both AC running. All of a sudden both AC shutdown. Any ideas.
My guess is the breaker on the gen. tripped, both unit starting at the same time, draws quite a but of amps.
Jul 04, 2011 | Dometic Rooftop RV Air Conditioner
Trying to install a roof top AC in my van. Can I run it off of a converter box from a cigarette lighter?
No, it will pull way too much power for that...thay pull about 20 amps @120V which would be 200 amps at 12v...get the picture??
Many RV's have a 120v AC generator that they run to power these...
heatman101
Aug 19, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioner
Airconditioner compressors has so little voltage tolerance, if voltage is lower than its rated, it will not run at all. I suggest you let the generator run at full first before turning on your airconditioning.
May 08, 2009 | Dometic Rooftop RV Air Conditioner
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Fedders Appliance Air Conditioner In-Window Logo
23 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
