Question about Tablets & eReaders
Where can I find a replacement 3555A2L battery for my Kindle Fire D01400?
Where can I find a replacement 3555A2L battery for my Amazon Kindle Fire D01400? Mine needs to be replaced.
  • 59 Answers
Here is a site that sells the replacement 3555A2L batteries for the Kindle Fire D01400:
3555A2L Battery for Amazon Kindle Fire D01400
Posted on Jul 17, 2013
  • 846 Answers
SOURCE: Damaged Kindle 2 Screen
The screen needs to be replaced and you have to fully disassemble it to do that. You can try to replace it yourself or send it to a third party Amazon Kindle repair service.
Posted on Aug 05, 2009
jyackle5
  • 8197 Answers
SOURCE: How do I use my new Amazon kindle?
Go to link below for manual
http://s3.amazonaws.com/kindle/Kindle_User_Guide.pdf
Posted on Apr 19, 2010
  • 331 Answers
SOURCE: Brightness on my Kindle Touch 3G
The Kindle 3G using E-Ink does not have a backlight therefore there are no brightness controls provided which in turn helps to increase the battery life.
If you need to have a reading light when using the Kindle then you will need to purchase one of the many clip-on LED reading lights that are available on the Amazon and other web sites.
Posted on Dec 29, 2011
  • 331 Answers
SOURCE: i need to reset my amazon kindle
You can enter the password as "resetmykindle" in place of your lost or forgotten password and this will reset your kindle for you.
Doing the above will delete all the content from your Kindle and will also deregister the device so once complete you will need to go to the Kindle Support web site and register the Kindle and transfer any purchases back to the device.
Posted on Dec 30, 2011
  • 16 Answers
SOURCE: kindle is stuck in the Amazon.com kindle store can't get out
Hold the power button to the right for 30 seconds. (Time them- not "One thousand one, one thousand two, ect." because this isn't precise enough.) This will reboot the Kindle and it should work. The reboot may take a while if it has been a long time since your last reboot.
Posted on Jan 03, 2012
Where can I take a kindle fire to get battery replaced
Amazon Kindle Fire HD
Kate, The source, radio shack, computer repair store or even a friend that is some what knowledgeable about computers. Kate you can even google search (Amazon Kindle Fire battery replacement) and maybe do it yourself after watching video or reading guide. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Good Luck.
How to Replace Your Amazon Kindle Fire Battery
Kindle Fire Battery Replacement
Kindle Fire HD 8 9 Battery Replacement
Apr 05, 2016 | Amazon Kindle Fire HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
New battery for Kindle Fire?
Step 1 - Back Case
  • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
  • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
  • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Step 2
  • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Step 3 - Battery
  • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
  • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  • step 4
  • Repeat the process from the previous step to free the left battery cell.
Step 5
  • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
  • Pull the battery out of the Kindle Fire.
Oct 31, 2015 | Amazon Kindle Fire HD 7in, 32GB
What do i do when i dont know how to register my kindle fire 1st generation
Contact www.amazon.com Next to the search bar you'll see Your Account. click, choose Your account from the list and click. Next page, far right column you will find help desk options. follow that to leave a message for them. They can send an email with instructions or call you back and walk you through it.
Aug 02, 2014 | Amazon D01400 Kindle Fire 1st Gen 8GB WiFi...
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
Kindle keeps turning itself off
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle.
Step 1: Press and hold the power button for 60 seconds
Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
Mar 26, 2013 | Amazon Kindle Fire HD
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
Dec 31, 2012 | Amazon Kindle Fire HD
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
Sep 24, 2012 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Kindle fire has red battery showing. I have charged it but it wont work
It may be the power cord but it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it started flashing a red battery symbol this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
Tablets & eReaders Logo
104 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
