Question about Cell Phones
Nokia 113 v 03.32 - Cell Phones
I have a Nokia e7 smartphone and need a nokia account
Discontinued!
What is the use of Nokia account? Nokia Account uses your email address, phone number or username and password to identify you when you access Nokia applications. You created a Nokia Account when you set up your Nokia mobile phone or when you first used a Nokia application.
'Nokia Account Discontinuation' on April 25th
allaboutwindowsphone.com/flow/item/20505_Nokia_Account_Discontinuation_.php Search for: What is the use of Nokia account?
  1. Swipe left to view the Apps list.
  2. Tap Settings.
  3. Tap Email + Accounts.
  4. Tap Add an Account.
  5. Tap Nokia Account.
  6. Tap the Email field.
  7. Enter your email address details.
  8. Tap the Password field.
More items...
Create a Nokia Account - Windows Phone 8 - Spark
https://www.spark.co.nz/help/mobile-data/.../create-a-nokia-account-windows-phone-8/ Feedback About this result
My Account / Register - Invent with Nokia
https://inventwithnokia.nokia.com/registration
  1. Cached
  2. Similar
My Account / Register · What are the financial terms? Blog · Login · Register · My Account / Register · What are the financial terms? Home > My Account ...
https://www.spark.co.nz > ... > Mobile & Data > Device > OS > Windows Mobile
  1. Cached
  2. Similar
Swipe left to view the Apps list. Tap Settings. Tap Email + Accounts. Tap Add an Account. Tap Nokia Account. Tap the Email field. Enter your email address details. Tap the Password field.
How To Create a Nokia Account - Ccm.net
ccm.net > How To > Mobile > Nokia
  1. Cached
  2. Similar
Aug 16, 2016 - Note: The Nokia Store was discontinued by Microsoft in 2015. At that time, all users were transitioned to the Opera Mobile Store, which now ...
need nokia account Google Search
Dec 22, 2016 | Nokia Cell Phones
Unlock nokia 1611
You can get the unlock code for your Nokia1611 phone from Unlock-Zone.com and unlock your phone from Network lock easily.
Dec 25, 2014 | MYBAT Stereo Handsfree 014 with Package...
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Nokia c201 restriction code
you can get the restriction code for your nokia c2-01 from Mobileunlocksolutions.com
Feb 20, 2012 | DURAGADGET Pocket size Mapple Mobile logo...
How can i use my nokia 3250 camera as an pc camera
you will need to download Mobiola web camera from this web address
http://www.nokiahouse.com/download-nokia-software/Mobiola-Web-Camera-55.html
It will turn your phone into a high-quality web camera . Very simple to install and configure,
Mobiola Web Camera consists of two software components:
(1) a client application that resides on the phone, and
(2) a web cam PC driver compatible with any Windows application that can receive video feeds from a web camera including Skype, Yahoo, MSN, AOL IM, ICQ messangers, www.YouTube.com, www.MySpace.com and www.grouper.com.
PC PART CAN BE DOWNLOADED FROM
http://www.warelex.com
Compatible : LG KS10, Nokia 3250, Nokia 5500, Nokia 5700, Nokia 6110 Navigator, Nokia 6120, Nokia 6121, Nokia 6290, Nokia E50, Nokia E51, Nokia E60, Nokia E61, Nokia E62, Nokia E61i, Nokia E65, Nokia E70, Nokia E90, Nokia N71, Nokia N73, Nokia N75, Nokia N76, Nokia N77, Nokia N80, Nokia N81, Nokia N81 8GB, Nokia N82, Nokia N91, N91 8GB, Nokia N92, Nokia N93, Nokia N93i, Nokia N95, Nokia N95 8GB, Samsung i400, Samsung i450, Samsung i520, Samsung i500, Samsung i560.
Have a great day!
http://www.pdxcellservices.com
Mar 30, 2011 | Cameras
How to use wifi
Hey there! According to my research. It seems that, this current Nokia model you have is a classic and does not have WiFi built-in Also, I've seen many with this model, in the end find out there is no WiFi in it.
However, if you'd like to use WiFi in Nokia models; You can try: The new Nokia Xpress touch - NOKIA N96, NOKIA N78, another option can be express music 5800 , n900, 5800 Navigation Edition, 5530 XpressMusic, E72, E52, Nokia N86, Nokia E75 , Nokia E55 , Nokia 6710 Navigator , Nokia 5630 XpressMusic , Nokia N97, Nokia 6260 slide , Nokia E63 , N85, Nokia N79, Nokia E71 , Nokia E66 ,Nokia 6300i , Nokia N96 , Nokia N78, Nokia N82,Nokia 6301 , Nokia E51, Nokia N8
I wish you luck! p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post id helpful to you at most!
Don't forget to rate! :)
Jan 15, 2011 | Nokia 6300 Cellular Phone
Hello i need master code for nokia E75 p help me
NOKIA E75 falls under BB5 group..and its master code can't be generate by master generator.. but for this solution you can try it..
Nokia BB5 Security mastercode reset
These newer BB5 phones require software to reset the security code:
Nokia 3250, Nokia 6125, Nokia 6131, Nokia 6270, Nokia 6280, Nokia 6630, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 7370, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93,
Nokia BB5 security code reset procedure:
* Connect your phone via USB cable in pc mode
Sep 04, 2010 | Nokia E75 Cell Phone
Regarding BL-5C battery blast
Here's the list of phones that should replace their batteries Nokia 1100, Nokia 1100c, Nokia 1101, Nokia 1108, Nokia 1110, Nokia 1112, Nokia 1255, Nokia 1315, Nokia 1600, Nokia 2112, Nokia 2118, Nokia 2255, Nokia 2272, Nokia 2275, Nokia 2300, Nokia 2300c, Nokia 2310, Nokia 2355, Nokia 2600, Nokia 2610, Nokia 2610b, Nokia 2626, Nokia 3100, Nokia 3105, Nokia 3120, Nokia 3125, Nokia 6030, Nokia 6085, Nokia 6086, Nokia 6108, Nokia 6175i, Nokia 6178i, Nokia 6230, Nokia 6230i, Nokia 6270, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6631, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 6820, Nokia 6822, Nokia 7610, Nokia N70, Nokia N71, Nokia N72, Nokia N91, Nokia E50, Nokia E60 The battery name is BL-5C
Aug 15, 2007 | Nokia 1100
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
