Recently I had to reload everything on my cpu, I re-installed the video drivers and then was trying to change the monitor settings. I think I may have set them too high for my monitor? which is now causing this error. The monitor displays fine during boot up, will just change to this error after windows xp starts to load. Is there a way to change the resolution prior to windows xp loading? Thank you.
SOURCE: Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
If your PC is working with a different monitor then your monitor is going bad.
This is resolved
