My sreen whent blank and i would like to know how to get my numbers off of it or copy them to the simm some how
Mine has done that a couple times. shut right off and i couldnt turn it back on. all i do is take out the battery and then put it back in and it boots right up.
Can you see shadows images - which indicated the device is ok and you have lost the back light so the can by peering at the screen sill function or is it completely dead- in which case the total system has failed.
This seems then a board component failure.
What sort of access to memory/data does it have?
USB for example
All I suggest you can do is to try to connect it to another computer to see if you can pull off any data on the device
I would not know about a repair on one of these- the Makers website may offer a solution
the screens black no color the key bad does not light up either but the sle key pad does
I took out the battery to see model # and after a few hours my screen went blank had to take out battery again to power it, did I do something wrong or
will this correct itself?
My screen froze earlier when it was locked and wouldn't unlock or turn off or anything so I took the battery off and now it won't do anything at all when I put the battery back in. I tried putting it on the charger but that has not helped either?
Thank you!
the screen is just blank green
exact same problem
screen block out
yesterday my phone was working and this morning turnoff. i try too turn on and tha screen is black
the phone itself works, and i receive calls but the screen is black
I had drop my phone outside now the screen is just blank black how do i get my #s out the phone and the phone can have incoming calls what do i do
