Question about Boating
Mercury 90 hp
Engine runs great. does not idle well. always stalls
Go a 16th at a time out with mixture screw richen the carb does it pop while idleing
Posted on Jul 18, 2013
I have a 1995 mercury 3 cyl 90 hp outboard motor serial number 0G255422. The reverse has been woring normally but now the gears just grind when switching to reverse. The shift action is stiff.
Is the engine idling at normal speed? To fast an idle will cause this. If the transmission has its own fluid is it full and clean?
Jul 14, 2017 | Mercury Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Intermittent fuel pressure drop, to 5 psi, on a stratus 2.4l 1996
Sounds like a bad fuel pump to me.Or dirty fuel lines/injectors/regulator.
Mar 22, 2013 | 1996 Dodge Stratus
1987 90 hp mercury outboard kills when putting it in gear
sound like a fuel issue if the engine set for a long period you may need to clean the carburators sounds like they are clogged
Jul 06, 2012 | Boating
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Engine wants to stall but it dont die and then it runs great
it could be the ignition module ,idle air control ,mass air flow sensor ,could be a long shot but, could be a partially plugged catalytic converter
Feb 18, 2011 | 2000 Mercury Sable
Missing a vacuum hose on the engine near the firewall i found where one end of the hose goes but not the other. and my 90 mercury cougar has a high idle and cant get it to idle down always have to ride the...
vacum leak will cause the high idle.with car running listen for suckin sound around intake.there may be vacum hose routing diagram on underside of hood.
Feb 13, 2011 | Mercury Cougar Cars & Trucks
I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Apr 20, 2010 | Raymarine Linear Feedback Unit For...
1996 mercury mystique stalls when I stop a red light
I am a Ford tech (35 years) and this is the cause of the problem in about 90% of the cars I see with this problem.
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Apr 29, 2009 | 1998 Mercury Mystique
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
