Danby dpac8020 is leaking from base
I have a Danby dpac8020 air conditioner that just started leaking water from the back left bottom corner. Until now the machine has run beautifully and I've only ever had to empty the internal and external water tanks and wash the filter. The rate in which the water is dripping seems to be consistent with how quickly the water tanks fill and I suspect the water is coming out the bottom rather than into the tanks as it should. I'm ready to take this thing apart. Any suggestions?
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
SOURCE: external water tank
Dear ziba1--posted the same problem two days ago and it doesn't appear to be on the site yet. Anyway, picked away at this again today (literally took the machine apart) and found the problem to be a clog in the drainage system. This explains why your external tank will not fill and why there is a leak--the drip tray under the compressor is not draining due to the clog in the drainage system. I fixed this simply by taking a narrow device and gently scraping out the drain hole of the drip tray (which is located just below the compressor...the compressor is located on the same side as your air filter). After successfully cleaning out this drain, I proceeded to flush the water out thoroughly with water. Give it a try--worked for me. I had all but given up and had already set up an appointment to have it serviced. Cheers
Posted on Aug 01, 2007
ranger25
  • 72 Answers
SOURCE: Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Posted on Jan 27, 2008
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
SOURCE: Manual
found it here: http://www.retrevo.com/support/Danby-DPAC8020-Air-Conditioners-manual/id/886bh630/t/2/
Posted on Jul 25, 2008
I have an everstar mpm1-10cr-bb6 and its leaking water from the bottom.
check the condensate tank to be sure it is empty and installed correctly, also make sure the unit is level.
Jul 21, 2011 | Danby DPAC8020 Air Conditioner
Just got a used everstar mpk-10cr and its leaking on the bottom of the back of unit.. is there supposed to be a plug there also? it has a plug higher up on back.. I know that the water pan on the side is...
Yes there is supposed to be a screw in plug. You can probably order one directly from Danby
800-496-6049 Make sure you have the correct model numbre when you call.
Hope this helped you. Please let me know. Thanks.
Jun 19, 2011 | Danby DPAC8020 Air Conditioner
How to recharge, danby, model, dpac8020
YOU PROBABLY NEED TO WELD IN SCHEREADER VALVES AND A LOT MORE JUST GO TO THE CORNER STORE AND ASK THE NEXT THIRSTY A/C MAN THAT SHOWES UP TO DO IT FORYA AND ADD A BRIBE HERE
Jun 11, 2011 | Danby DPAC8020 Air Conditioner
What is the P2 code on an everstar mpk 10cr1
<b>Unit Displays P1</b><br /> P1 error indicates that:<br /> <ol type="A"> <li>The water tank on the side of the unit is full. <li>The water tank in not properly seated in the housing. <li>The switch at the back of the water tank housing is not engaged or is loose </li></ol> <br /> <i>Solution</i>:<br /> <ol type="A"> <li>Empty the water tank. <li>Make sure the water tank is properly secured in the housing <li>Remove the water tank for the housing and gently tilt the switch at the upper left hand corner of the housing towards you. This should allow the tab on the water tank cover to engage the switch. </li></ol> <br /> <b>Unit Displays P2</b><br /> P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <i>Solution</i>:<br />Move the unit to a location that is suitable for draining water from the unit.<br />Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)<br /> <hr color="#cccccc" size="1" /> <b>Unit Does Not Cool/The Green Light is not on. </b><br /> Is the unit in the Cooling mode?<br /> <i>Solution</i>:<br />Press the mode button until cooling mode is selected. <br />Lower the temperature setting on the unit to the minimum setting. <br />(The temperature setting of the unit has to be lower that that of the room)<br />Wait 3 to five minutes for the compressor to start running.
Jul 06, 2010 | Danby DPAC8020 Air Conditioner
P2 err on mpk-10cr it starts for about 5 seconds then p2 displays and it stops can you gide me to were the problem is
P2 error indicates that the spill reservoir in the base of the unit is full.<br /> <br /> Solution:<br />Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain <br />(Remember to replace plug.)
May 25, 2010 | Danby DPAC8020 Air Conditioner
Where can i buy an external water tank for dpac8020 i live in montreal quebec
IM A DANBY SERVICE PROVIDER IN USA...GIVE ME ALL INFO...ILL CALL AN FIND OUT...MICHAEL DOCTOR AIRR APPL.REPAIR 843-384-8474..SOUTH CAROLINA TIME...IF NO ANSWER LEAVE MESSAGE...
Mar 26, 2010 | Danby DPAC8020 Air Conditioner
The air onditioner leaks water, can't remember if
Mine is a different brand, but it has a "bucket" in the back I have to empty every day.
Jul 24, 2009 | Danby DPAC8020 Air Conditioner
The LCD says "P1"
Bottom tray is full -- Remove the bottom plug and attach the drain hose and drain the water away. If error repeats, call for service.
Jun 07, 2009 | Danby DPAC8020 Air Conditioner
Manual
Jul 01, 2008 | Danby DPAC8020 Air Conditioner
Danby air conditioner model #DPAC10060(R)
here is the manual link: http://www.danby.ca/manuals/DPAC8020.pdf
Jun 03, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
