Question about Spectre 2006 Ford Econoline - E150, 5.4L V8 - Air Filter
2006 E150 FORD WITH ENG CODE PO446
EVAPERATOR EMISSION CONTROL
What is the SPINDLE in the front brake system?
In the average brake system this refers to the tapered stub on the front suspension knuckle, which mounts the front hub and bearing assembly. It has a thread on the end for the front hub nut (not wheel nuts).
The actual appearance varies widely from car to car.
http://www.ss396.com/mm5/graphics/00000001/FM-3712.jpg
Nov 12, 2014 | AM Auto Parts 1997 to 1999 Ford E150 Van...
How to find small air leak
Get some starting fluid and CAREFULLY spray a tiny bit in various areas around the manifold, air intake area - when you hit the leak, the engine speed will increase.
Nov 10, 2014 | Spectre 2001 Ford Econoline - E150, 4.2L...
2006 Toyota Highlander 4 cyl. has VSC and TRAC off lights on?
Press the "traction-control" button/switch to turn on/off the 'TRAC' button.
May 19, 2014 | Spectre 2006 Toyota Highlander - 2.4L...
How do you fix a code P 1506 ?
Hi Joel,
Here's what you were looking for. Idle Air control valve
http://upkeep.us/OBDII/OBD2/Ford/piart.php?art=5282
2.3L 2002 Ranger part page for reference & repair video. Same engine, etc...I do not work for Rockauto it's just a part/price reference.
http://www.rockauto.com/catalog/x,carcode,1372676,parttype,6072
Repair video
https://www.youtube.com/watch?v=iQr6E9Z7sg4
FYI, video for IMRC shows issues which are sometimes related.
https://www.youtube.com/watch?v=qLqpQeIJXek
PEACE
May 09, 2014 | aFe 2001 Ford Ranger - 2.3L 4-cyl. engine...
It wont do nothing when I shift it to D and on R it just jump
You need a transmission overhaul. There are too many reasons to look at here so I'd look around for a reasonably priced repair shop.
Jan 14, 2014 | Spectre 2000 Ford Econoline - E150, 4.6L...
Code po351
Its not the plugs. It is either the ignition coils or the crank sensor
May 06, 2013 | Spectre 2006 Ford Econoline - E250, 4.6L...
Mitsubishi fuso 2008 check engine light
Hello
When the service engine soon light (Also called the check engine light) is turned on this is to alert you to the fact that powertrain control module (computer) has detected a failure somewhere in the systems it controls, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Jun 23, 2012 | Mitsubishi 4 Fuso Truck Fe 2005 / 2008 Air...
Spectre 2006 Ford Econoline - E150, 5.4L V8 - Air Filter Logo
32 people viewed this question
Top Spectre Air Purifiers Experts
 Russ Hill
Russ Hill
Bill Boyd
Lawrence Oravetz
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
