Question about Air Lift 1989 Ford E-350 Econoline Club Wagon Air Leveling Kit
Fuel problems I have had this 89 e-350 with a 460cid for 10 years and I have always relied on the front tank (the rear tank leaks over about 5 gal.) I have had problems with what I thought was vapor lock, in stop and go traffic, and I would then switch to the rear tank and i would be fine..Now about ten thousand miles ago, all the fuel from the front tank would return to the rear tank , so I disconnected the rear tank(I did a loop on the tank selector valve) ow i am having the same problem of running out of fuel when it gets hot..any suggestions? vapor lock? front tank pump getting hot and foaming? I don't want to spend alot of cash as this things about ready for the boneyard, but need to finish up the summer..any suggestions will be appreciated
  • Air Lift Master
  • 16,010 Answers
Sounds like the pump is done. This problem could be related to using gasoline that has alcohol in it.
Posted on Jul 21, 2013
Testimonial: "You seem to be correct...I switched lines to the rear tank only and it seems fine...Now the problem is for some reason the fuel gauge does not work when switched to rear tank..I have an electric switch for switching tanks, and it used to work fine...Any ideas...thanks"
Im not using my front fuel tank because it has a leak, just using the rear tank,but fuel is still going to front tank,please help, fuel selector switch is on rear tank ?
You have 2 problems. First is, the leak, fix it. Second is the actuator / fuel solenoid on the frame is bad also. You shouldn't get fuel to the other tank when you switch from front to back.
Dec 21, 2016 | Cars & Trucks
What is the fuel consumption 40hp yamaha outboard
Scott, 40 hp with 5 gal tank about 1/2 day or 3 hrs continuous. always carry and extra 2 to 5 gal if your way out from marina
Mike
Apr 24, 2016 | Boating
Have a fuel leak from top of tank when refeuling
Did you check your fill tube, is this a hose or pipe? Also, check your evap system. When the problem is ongoing, can you get under the vehicle to visually see the leak.
Is there a vent hose you can check? Does 5 dollars fill it up?
Nov 21, 2014 | 2000 GMC Jimmy
Have an atwood 10 gal water heater that leaks but I can't find the leak. The lines are dry. Have a lot of water in interior under the bathroom tile.
Also open cover and check if element is leaking. Elements frequently leak at rubber seal.
Next suspect is rusted-out tank that is leaking through a thin-place in the tank.
Otherwise there are not many other places to check if pipes are dry, especially with the Atwood 10 gallon.
I suggest replacement.
http://waterheatertimer.org/Water-heater-is-leaking.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | RTO Atwood Water Heater - 6 Gal LP
Not getting fuel. told not to use the rear tank
I had an 86 F150 with dual tanks, it had a similar problem. The problem ended up being the switcher valve (switches from one fuel tank to the other). Mine was electrically controlled and would switch from rear tank to front tank, but (front tank also had a leak) would not switch back to rear tank. I found out that my switcher valve (after I tried rebuilding the switcher valve myself, and determined that it was not repairable and needed replacement) was defective. They are also not cheap-about 10 years ago it was about $150! Don't know if yours is the same model, but I found the easiest thing for me to do then was remove the front tank, since it leaked (metal mounting straps worn through in spot where insulation came out sideways), and remove the switcher valve. I always left my tank switch set to REAR (dont know if anything would have happened if I had moved it to FRONT anyway, with valve and tank gone) and it always worked fine from then on out.
What you need to do is probably a 2 man job: Have someone inside the cab have ignition on and work the switch from one tank to the other, while you are underneath the truck at the switcher valve. Your job would be to determine if the valve actually works both ways, or just one way, or not at all.
Also there are fuel filters in several places: there is one in the switcher valve, further up along the frame toward the engine, and should be one somewhere on the engine, too. Also each tank should have an in tank pump. Several places to check, it's a big job, its messy, gasoline is toxic, not to mention explosive. Wish I had better news for you.
Hope I've been helpful.
Mar 13, 2010 | 1987 Ford F 250
The car only have 43,000 ml on it but it have
first drain the engine oil and oil filter.next replace the battery and clean the battery cables.then you will need to siphon out the old gas or if below quarter of tank added 5 gal. of gas to gas tank then disconnect dist.ign. lead on side of dist.and crank engine over with out starting.for about 10 sec. do this 4-5 times then crank over for 30 sec.this will help get oil to the bearings.next hook up the dist. and check all wires for rodent chewing and repair if found.then check antifreeze in radiator may need to change along with thermostat,and possible all hoses they may be dry rotted. the front seal on the water pump may start leaking after running so you may want to replace. try and start engine.do not drive. wish you the best let me know how it goes.
Nov 03, 2009 | 1995 Buick Riviera
1986 ford crown victoria no start
Was there any gas in the car before you added 5 gallons? If there was, it is the problem. The gas goes bad, especially if left in the car unused that long. The system will need to be flushed out (lines, tank, carb/or injectors cleaned.
Also, carefully inspect the entire brake system, as flex. rubber lines can dry rot, steel lines may be rusty (if rust was present when parked, even though the garage is dry). You will probably need to disassemble the calipers and brake cylinders, clean them, and flush the system out. Your tires probably need to be replaced also, as they may fail under high temp conditions (dry rot). I have stored cars over the years, not always in the best conditions, and the worst thing for a car is to have it sit unused.
Mar 29, 2009 | 1986 Ford Crown Victoria
I have a Monitor 30, it comes on and just runs, it will not lite until I lift the primer once or twice, then it heats fine. I checked the filter and made sure the tank was high enough for a 5 gallon...
Rob,
You have some kind of fuel problem. When you mention 5 gals of fuel, that leads me to think you need more fuel ( more pressure). If you have a large tank and only have 5 gals you may no have enough head pressure to push the fuel through the line and all the filters in the system. That being said the Monitor 30 is the oldest vented heater around. Parts have not been available for 15 years. The thing that scares me about the M30 is the flame safety circuit. I don't think it is adequate. If you rely on this heater to keep pipes thawed I would get a new Monitor or Toyo.
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Ford Dual Gas Tank problem, Rear tank Always full.
This is a common problem. On the driver's side frame rail is a large black plastic assembly that the fuel lines connect to. This a fuel switching valve what usually happens is the valve goes bad and the fuel gets pumped from one tank to the other
Dec 09, 2008 | 1992 Ford F150 SuperCab
Fuel gage computer problems
fuel gauge is controlled by a sending unit in the gas tank.
Nov 14, 2008 | 1990 Cadillac SeVille
Air Lift 1989 Ford E-350 Econoline Club Wagon Air Leveling Kit Logo
48 people viewed this question
Top Air Lift Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Are you an Air Lift Air Tool and Compressor Expert? Answer questions, earn points and help others
