Question about Sharp AR-507 Copier
5320 ar 5320e fuser unit not rotating - Sharp AR-507 Copier
5 Suggested Answers
  • 11 Answers
SOURCE: it dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Posted on Nov 28, 2008
  • 148 Answers
SOURCE: my copier AR-5320E is showing a number 4 and letter H
the fuser unit is not heating up
unplug the copier then plug back in
make sure the fuser area where you clear jams is latched down
close all doors
if this does not work your fuser lamp is burned out or a fuse has blown on the heater roller
You will have to call service
Posted on Jan 07, 2009
  • 59 Answers
SOURCE: AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
Posted on May 20, 2010
rezazadeh
  • 328 Answers
SOURCE: AR-5320 Black and White Copier: I NEED AR 5320 PRINTER DRIVERS. HOW CAN I GET IT...
my email is info@fajrshahab.com contact me tell your email i will send you
Posted on May 25, 2010
My sharp ar 5320 is showing H2 or 2H
check 4 the thermistor of ur fuser unit @ the paper exit side of ur machine .u can clean d dirty on the surface & check if the halogen lamp of the fuser unit is good
Jul 19, 2011 | Sharp AR-5320 Black and White Copier
thanks
May 18, 2010 | Sharp AR-5320 Black and White Copier
I need the software for ar-5320e
I need a share ar 5320e software .How can I get this software?
Jul 16, 2009 | Sharp AR-5320 Black and White Copier
What difernt betwenn ar 5320 and 5320 e
The AR-5320 comes standard with XY Zoom and Dual Page
Copy Mode. The AR-5320E has additional image editing functions (Rotation Copy, Margin Shift, Edge/Centre Erase, and 2-in-1/4-in-1) available with the optional AR-EB7 upgrade and you can uprade the memory for printer with optional AR-SM5 256 Mb
Apr 27, 2009 | Sharp AR-5320 Black and White Copier
My copier sharp AR-5320E is showing number 2 and letter H on the
H2 IS HEATER UNIT PROBLEM.IF SUB CODE IS 00 THEN IT SHOWS THAT FUSER THERMISTOR IS OPEN.USE SIMULTIONS 14 TO RESET IT.PROBLEM WILL BI SOLVED .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Jan 20, 2009 | Sharp AR-5320 Black and White Copier
My copier AR-5320E is showing a number 4 and letter H
close all doors
Jan 07, 2009 | Sharp AR-5320 Black and White Copier
My copier sharp AR-5320E is showing number 4 and letter H on the display thereby making intructing the copier impossible.
H4 is a fuser problem, normally a reset will cure, to reset press these buttons
#, interupt, cancel (c), inturrupt. Display should say 'enter simulation'
enter 14, start, execute.
Switch off then on and it should work
Cheers
It dosent enlarge the document in book copy mode in sharp ar 5320
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-507 Copier Logo
14 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
