Question about Acer Icona A1-810
Acer a1 810 wont turn on
It was fully charged and i turned it of for the night and today it does not do anything
I have an acer iconia 500 tablet, it worked fine last night ,but today it wont get past the acer logo on boot.tried to do a hard reset and push button reset no joy ,any advice would be welcomed
lol I know that feeling...you need to reinstall the bios...you can find them on a flash drive on ebay. Or go free and use a flash drive to get it free online...go to acer.com...Its a known problem by Acer :) update: My Acer 500 stopped working Friday, with the very same freeze at Acer startup screen detailed here. Reset button didn't work (there's a post here that said he pressed the vol/up button while pressing the Reset button-I've only been inserting the tip of a paper clip to press button, which is the correct way?
Did the hold power button while pressing vol/up then sliding lock button back and forth. "Erasing Cache" appeared, but screen goes back to Acer startup and nothing.
Found this thread from a poster at Androidtablets.net. Downloaded one of the zip files posted here. Went to copy to an SD card, Can the file be placed on a USB drive instead? While trying the power "Bootloader vo.03.12-ICS Fastboot USB Download
Aug 13, 2016 | Acer Tablets & eReaders
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
My Irulu 10" tablet will not turn on. I turned it off list night and today it will not turn on. I left it charging last night.
Try holding down power button for 10-15 seconds. If that doesn't work, try holding down up or down vol with power button at same time until screen comes on then release both.
Mar 04, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
My tablet iconia wont start
There should be a tiny reset button or pinhole (use a straightened out paper clip). If reset button/hole itself does not work, try pressing it while holding down the power button at same time. Otherwise, it sounds like you have a battery/charging issue (try another charger cord if available).
Dec 02, 2013 | Acer Tablets & eReaders
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
Jan 16, 2013 | HTC Amaze 4G Android Smartphone
Tabeo won't fully charge
I spoke with someone in their Tech department today about another problem and mentioned that I was having problems with it charging and he said that when I get back the device there is an update that needs to be installed in regards to the charging problem. So when you get a chance install all updates.
Jan 05, 2013 | Toys R Us Tabeo
Le pan tablet wont charge how to reset
Le pan tablet not charging after all night does not show battery when plugged in.tablet does turn on battery level about 30%?
Apr 28, 2012 | Tablets & eReaders
Wont turn on...before this it would shut off and then power on like it was loading a web page..I have only had this kindle since Christmas.
I received my 3g model for Christmas as well. Last night, it lost wireless connectivity, froze and then would not turn back on, even though it was fully charge. However, I charged overnight again.
This morning, I held the on switch for much longer than normal, until the green light started flickering. I received a simple black screen a few times, but contintinued to hold the switch on. Then it reset itself and all is good.
So I know that sounds like a simple solution, but maybe worth trying. Good luck. It's disgusting, I know. I was so upset.
Jan 24, 2011 | Amazon Kindle 3G
I have a Kindle DX. I turned it on today and it has a black page. How do I get it back to normal?
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Dec 28, 2010 | Amazon Kindle DX
Acer Icona A1-810 Logo
134 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
