Question about Baumatic B187 Stainless Steel Electric Single Oven
Baumatic 1870ss steel electric oven
Fan and grill works but oven does not heat up
  • Twedd Nov 12, 2007
    New home with integral electric cooker & gas hob. Sadly the oven will now not heat up despite fan working & grill too.
    I initially thought it may have been a result of the control panel buttons being fiddled with but this does not seem to be the case (this said I am without any intsrustions so cannot be 100% sure)
    Can any one help with either a tip or a copy of the intsructions for the control panel please.
  • Anonymous Aug 11, 2008
    I have the same problem, my feelings are that the thermostat is broken.
    Trying to find a replacement on the web.
Yep sounds like the element. You can get a replacement for about a tenner off ebay and it's an easy fit.
Posted on Nov 07, 2008
Sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
Grill and fan works but no heat to oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
May 15, 2011 | Baumatic B180 Electric Single Oven
My grill works but the oven doesn't heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Mar 31, 2011 | Baumatic B187 Stainless Steel Electric...
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Baumatic B187 Stainless Steel Electric Single Oven Logo
332 people viewed this question
Top Baumatic Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Pie-man
Pie-man
Level 1 Expert
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
