Question about Microwave Ovens
Emerson mw899158 micorwave
Control panel
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: What is best price for Micorwave control panel part # WB56X10817 and where is it available it best price?
It's just under $85 at Universal here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Some connectors on the relays have a lock:
Posted on Dec 20, 2011
Reset emerson microwave
There is no reset button. You will need a control board.
Dec 13, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
Dec 04, 2011 | Microwave Ovens
I have a GH7208XRS-1 microwave convection oven. The plastic shell of the dorr was cracked, so I took the door apart, replaced the plastic shell and plugged all connectors back together. Once I plugged the...
These units have some connection problems, especially in the keypad / controller areas.
One way to fix it is to take it apart, disconnect the connectors one by one, and then plug and unplug them a couple of times to wipe any oxidation away, then replug them and put it back together.
If that doesn't fix it, then you may need a new key panel or controller, but I don't have enough documentation on these models to help further. They are vastly overcomplicated, increasing the odds of failure.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 06, 2017 | Whirlpool GH7208XR Convection / Microwave...
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Have a whirlpool mh7130xez over range micorwave, everything works great but the suface light? beeps when i push the button? tried 3 new bulbs---please help
The relay for the lights is not working. No board level repairs. You will have to replace the control board to get this feature back.
Eric
Sep 01, 2009 | Microwave Ovens
My micorwave
Hi and welcome to FixYa,
Your described problem indicates that the logic circuitry in the main controller board is faulty. Since the logic circuitry is integral to the board, it would require an assembly replacement. On most brands/models, the main controller board is directly behind the display panel. In some instances, it could be a stuck key/button hence the logic would not reset.
Good luck and thank you for using FixYa.
Feb 13, 2009 | Samsung Microwave Ovens
Emerson Problem
Your Control Panel has failed. Replacement of the Control Panel is your only repair option. Not cheap!
Feb 04, 2008 | Emerson MW8987B/W Microwave Oven
H97
H97 is a problem with the inverter, bad magnetron or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 13, 2007 | Panasonic NN-S953 Microwave Oven
Emerson Micorwave oven MW8108P
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 30, 2007 | Emerson MW8108P Microwave Oven
Emerson 600 watt microwave
disassemble it and look for disconnections to control panel from faulty factory assembly
May 30, 2007 | Emerson MW8627W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
