Question about Movincool Classic Plus 26 Air Conditioner
Error code A5
What does error code A5 mean?
Washer won't start. error code A5 frigidaire affinity what does it mean
Main voltage sensing failure
You will need to replace the electronic control board.
Apr 19, 2017 | Frigidaire Washing Machines
Error code A5 on frigidaire affinity washer what does it mean? already replaced lock, striker, bushings.
The voltage sensing on the control board is bad. You need to replace the control board.
WHAT DOES 2615 CODES MEAN
is it P2615?
if yes then it means camp shaft signal output circuit low
Mar 14, 2016 | 2010 Audi A5
How do i scan photo with a5 paper
what do you mean with A5 paper? do you want to scan an A5 sized picture, or put a picture on A5 sized paper?
Feb 17, 2015 | Epson Stylus DX8400 All-In-One InkJet...
Frigidaire fas257q2a2
Hello Friend, I am happy to assist you!
I understand your Frigidaire air conditioner (FAS257Q2A2) is displaying error code A5; however, it appears the correct error code is AS. Error code AS typically indicates that your air conditioner is experiencing an issue with the ambient thermistor. I would strong suggest contacting a professional to check the wiring between the main control board and thermistor. A certified technician would generally replace the faulty part after proper diagnosis. Best regards! - Z
Jul 06, 2014 | Frigidaire FAC125P1A Window Air...
Displaying "A5"
Do you mean error code AS instead of A5? If so, error code AS commonly refers to a sensor issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage.
Dec 21, 2013 | Frigidaire FAD704DUD Dehumidifier
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
The fan runs, but we get an A5 error.
I think what you're actually seeing is an AS error. It's looks like A5 on the LED screen.
AS error means their is a sensor failure. So, before calling Frigidaire Tech Service
(800-444-4944), turn the Master On/Off Switch to OFF. Unplug the unit for 12 - 15 minutes.
This should give the unit ample time to reset itself. Plug the unit back in and turn the Master ON/Off Switch to ON. Now, set your controls as you normally do. If the unit starts up and runs as it should, the problem for now is solved. If it keeps re-occurring, contact Frigidaire Tech Service.
Apr 06, 2011 | Frigidaire FDF50S Dehumidifier
I have a Frigidaire front load washer with error 20?
Hello
Welcome to Fixya
My name is Huum,
E45 means A board communications problem/ Replace the control board!
At this site below is your manuals, both user manual and instruction manual!
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.brandName=FRIGIDAIRE&product.modelNumber=ATF6000ES&intcmp=A5
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Movincool Classic Plus 26 Air Conditioner Logo
79 people viewed this question
Top Movincool Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
