Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
SX200 Not Printing
I have cleaned the nozzle heads and removed all the dry ink but the printer will no print black. The colour cartridges are printing but very faint. Any suggestions on how to fix this?
  • Epson Master
  • 419 Answers
Not sure how you will have removed the dry ink but there will undoubtedly be more clogged ink in the printheads and nozzles themselves.
There's two approaches to resolve the issue...
1. Active
Through the use of a cleaning solution that you effectively force into the appropriate ink receiver on the printhead.
This can delaminate (technical term: knacker/mess-up) the printhead so avoid the use of anything other than the gentlest of pressure.
2. Passive
Get the printhead off the cleaning station (where it normally rests when not in use) and then soak the cleaning station pad with cleaning solution (so you have a puddle)... Return the printhead to it's normal resting position and leave the printer disconnected from power for a few hours. You then plugin and switch printer back on and it will purge the solution out of the cleaning station. Print one nozzle check then repeat as required. Be prepared to leave overnight to allow the cleaning solution to wick into the nozzles and break the clog does like soaking dishes in a sink.
You could use both methods in tandem to tackle the clog from both sides but patience and time are both critical ingredients. Expect it to take up to a couple of days.
Best of luck.
Posted on Jul 18, 2013
AlmostBob
  • 550 Answers
SOURCE: Black printing incorrectly
check whether there is an alignment adjustment in the printer driver, the lines may simply be one nozzle out of alignment., or the connector between the print carriage and cartridge may be dirty, causing that one nozzle to misfire
not a guarantee, just something to check
Posted on Sep 10, 2008
SOURCE: epson photo 995 - black ink not printing
This is a common problem I have found with Epson printers. If you don’t use the printer on a regular basis the printer heads can clog. I have found no way to clean the heads once this occurs. I will now only purchase HP printers because the printer heads are part of the ink cartridges. With every cartridge change you get new heads, end of that problem!
Posted on Mar 30, 2009
tigertail
  • 163 Answers
SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Posted on Apr 02, 2009
aicaxz
  • 511 Answers
SOURCE: faint printing after cartridge change & head cleaning
How about nozzle check output? Is it perfect? No missing lines? Do head cleaning, wait for 30 minutes. Check nozzle again. If there are no difference betwen two output, you may need cleaning head manually.
Posted on Sep 15, 2009
Alex93Serbia
  • 209 Answers
SOURCE: broken lines when printing with black ink
Hello there!
What printer are you using? with that software provided with printer ,there should be settings for cleaning that black nozzles. If you are using lexmark printers in which i have a lot experience, you will have that option available in software provided with it, but im pretty sure you will have it also with other brands such as HP,....
Please rate solution! =)
Sincerely
Aleksandar Adzic
Posted on Apr 16, 2010
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Colour ink not printing
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the "Ink" option in the printer driver may be set to "Black" instead of "Color" or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged.
A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, turn the printer off overnight and try the cleaning cycles again.
Try a new ink cartridge. Also, make sure you are using a genuine ink cartridge and has the same number as your old catridge.
Jun 20, 2011 | Computers & Internet
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
One colour cartridge on epsom sx200 is empty yet it wont allow me to print in black only
umm... this is not a solution because I don't think there is one apart frombuying new inks. Epson and all other inkjet printers do this to preventthe coloured print head nozzles from getting blocked. If they are notused for a long time the ink dries up and blocks the nozzles. Epsonrecommends printingat least once a month with all colours to prevent this. Printing inblack only option will only work if the colored inks are OK. Wheneverthe printeris turned on it performs a head clean, this is why the coloured inksget used over time even though they are not used for printing.
www.Quikshiptoner.com
Nov 25, 2009 | HP LaserJet 2840 All-In-One Printer
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
I just want to print a word document in black ink, but...........
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. ( Also Epson gets to sell you more cartridges)
Apr 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Why is it that my printer won't work if one ink cartridge is empt
Mar 31, 2009 | Epson Stylus CX7000F All-In-One InkJet...
Epsom R340
print a nozzle check from the maintenance menu
see which colours are missing, run through a few head cleans and print another nozzle check see if there is any improvement
also replace the cartridges of the missing colour they may be dried up. have seen this before where a 3/4 full black cartridge just completely stopped printing
if the problem still persists then get a syringe or an eye dropper and some form of spirit (I have used vodka in the past but clinical alcohol is recommended as not as sticky)
choose change cartridges from the menu then remove the power cord. with the cartridges removed you now have access to the printheads.
using the syringe (or eye dropper) place the nozzle on the spike that goes into the cartrige and inject a small amount of the alcohol leave this to soak for a few mins then mop up the excess with a cloth repeat this a couple of times put the ink back in power up and run another head clean (you can also put afew drops on the spounge that sits under the print head during the head clean
print the nozzle check again you shoudl see most of the nozzles are now working run another head clean if desired now try with a pic
have used this on various epson printers including a stylus 700 R340 & 360
Jul 27, 2008 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
