Question about Kenmore 20.6 cu. ft. Upright Freezer 2809
How to fix temperature on my kenmore elite upright freezer
Hi my parents went out of town for a week and a couple days went by and we went to see if everything was alright. But the door on the upright freezer was ajared and was open for probably 2 days with alot of food still in it but thawed mostly. how can i make sure the right temperature is right cuz i played with it cuz its taking along time to freeze back up since i shut the door we waited 24 hours. my email is dusty_grim@hotmail.com thanks
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 12, 2008
  • 1462 Answers
SOURCE: kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Posted on Oct 16, 2008
kachbibi1
  • 979 Answers
SOURCE: FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Posted on Feb 17, 2009
goodwinpeg
  • 744 Answers
SOURCE: How do I fix freezer drain in Kenmore Elite french door refridgerator
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
A frozen or blocked drain may not be the problem, or it may.
You have one of two problems. Regardless of which problem it is you need to remove the back wall panel in your freezer. This is not a easy task. You must remove the freezer door, the ice maker, the side guide rails. There are two clips on the back wall air distribution center section using a screw driver to depress and then some. You need to install a hot wire from the bottom of the defrost heater to the drain. Do not attempt this, you may damage some of the components if you do not have the experience.
Ok, lets check out the frozen drain the easy way. Your unit goes through a defrost cycle every 8-10 hours. This is where everything shuts down for 20-30 minutes with the exception of your lights. Your defrost heater turns on during this time.
1.) Check the Drain:
a.) Pull your unit out from the wall to where you can get behind it. You may have to raise up the leveling jack screws in the front to do this. Remove the bottom toe plate. There are two Philips head screws holding it on. Turn the jack screws counter clockwise to raise.
b.) Having pulled the unit out from the wall, unplug the unit. Remove the bottom back cover. There are several hex head screws holding the cover on.
Pull the drain tube out. It just Pops in and out. If there is a black rubber grommet at the discharge end, remove it and throw it away. The initial intent was to keep warm air from getting into the freezer. However, over time they dry up and prevents the condensate from draining.
c.) Insert a wire up into the drain hole, such as a coat hanger, to check for blockage. If it is blocked with ice, you must unplug your unit for 24 hours to completely clear the ice.
2.) Obstruction or Refrigerant Leak:
Recently, I believed my friend had a frozen drain in the same unit that you have. Upon pulling the back cover I discovered a block of ice build-up at the refrigerant and capillary tube connection. The capillary tube is about 1/16" in diameter with a small needle size hole running through it. This tube can easily become plugged, which is common. This block of ice will continuously drip. A repair of this nature is about $450.00 - $550.00. The rule of thumb is: "If the cost of repair is 1/3 or more of the original cost of the unit, then replace the unit. You can get some good deals at a Sears Outlet (Scratch & Dent) Store.
Posted on Jan 19, 2015
Does Kenmore Elite upright freezer reach -20 degrees celsius, where is the info?
Best way I can answer this is to purchase the right equipment for the job. A domestic freezer is not designed to work like that, although it may get there in temp it won't hold it. Recovery is slower then the industrial unit you seek. Domestic unit warranties are void if used for commercial settings (i.e. lunch rooms, offices, lab's, etc...) I wish I had a better answer for you but if you need a specific temperature get the correct equipment for the job. Good Luck
Jul 31, 2014 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Kenmore 20.6 cu. ft. Upright Freezer 2809 Logo
79 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
