Question about Soleus CFM-40 Dehumidifier
How do I take the back off of a Soleus CFM-40 Dehumidifier?
I got the bottom and top set of screws off, but there's a middle set that I can't figure out how to unscrew. They're screws I've never seen before and none of the screwdrivers I have work.
  • 883 Answers
SOURCE: No water in bucket
if you can verify that the compressor motor is actually turning, then the problem is either a freon leak or a worn out compressor. if it is not turning, then the problem is either a damaged motor or motor is not getting voltage--need testing with meter to determine why. cheaper in long run to buy a new unit if bad compressor or motor or freon fill, but a fill may be only temporary if leak persists.
Posted on Aug 17, 2007
raymondguy
  • 3 Answers
SOURCE: Soleus 40 pint dehumidifier... used for 3 years,
Check to see if the styrofoam is still in the lever of the shut off arm. It's atop the water reservoir. If there is nothing there it will not float causing the arm not to shut off.
Posted on Dec 05, 2009
  • 117 Answers
SOURCE: I need a repair part
contact@soleusair.com
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: Soleus CFM-25 dehumidifier fan works,
If everything you are saying is true then refrigeration system has lost the freon charge..
for the charge to be lost there must be a leak also...
Till you find the leak and recharge the unit it will cost more then a new one...
heatman101
Posted on Dec 14, 2010
heatman101
  • 43501 Answers
SOURCE: My 40 pint Soleus dehumidifier doesn't pull any
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
My soleus dehumidifier keeps tripping my fuses on my powerstrip so we have to keep resetting it. Why?
If it is a GFI protected powerstrip then you likely have a ground fault issue, otherwise the powerstrip may be overloaded (unit should pull around 5 amps on startup) or faulty.
Sep 25, 2011 | Soleus CFM-40 Dehumidifier
The drawer is empty of water but the signal says 'full'. Is there a broken part? Thank you, Eileen
No, probably not. Either the float valve in the top of the bucket (drawer) is stuck in the 'UP' position or the bucket wasn't installed properly.
For the stuck float valve. Remove the bucket and look in the right or left corner of the bucket for the float valve. If it's stuck in the 'UP' position, jiggle the handle to make it return to the 'DOWN' position.
When reinstalling the bucket into it's holder (whether it had a float valve or not), be sure that it fits "squarely" from top to bottom into the holder. It should not tilt down at the bottom. The bucket must make firm contact with the bucket safety removal switch inside the holder.
Hope this helps you to troubles shoot and solve the problem. Please let me know. Thanks.
Jul 14, 2011 | Soleus CFM-40 Dehumidifier
Doesn't dehumidify at any temperature any setting, compressor works, good air flow.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 14, 2011 | Soleus CFM-40 Dehumidifier
This dehumidifier continues to run after it is full, spilling water out of the full tank. How can I fix this?
Diane, the float valve in the left top of the bucket (it's styrofoam) is stuck and can't shut the unit off when the bucket is full. To help you solve this, I am providing a link to your Owners Manual that will help you with this problem You can download and print the manual for future reference Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to solve this problem.
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Hope this helped you to solve the problem. Please take a moment to rate my response to you.
Thanks.
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
Soleus Air Dehumidifier Model CFM-25E has stopped working after about 1-1/2 years.
heatman101
Apr 21, 2011 | Soleus Dehumidifiers
My 40 pint Soleus dehumidifier doesn't pull any water into the tank even though the fan blows normal.
heatman101
Jun 18, 2010 | Soleus CFM-40 Dehumidifier
Soleus 40 pint dehumidifier... used for 3 years, stopped making water. Recently overfilled, auto shut off hadn't worked and water level overflowed. 2 days later can't get to make water. Tried all the...
Nov 25, 2009 | Soleus CFM-40 Dehumidifier
Soleus CFM40E
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Soleus CFM-40 Dehumidifier Logo
49 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
