Question about Refrigerators
Where is the thermstat on my wc900 wine cube
MY BONJOUR WINE CUBE WILL NOT CHILL...IT STAYS ON 73 DEGREE...
2 Suggested Answers
  • 11 Answers
SOURCE: bonjour wine cube #53372
The Bonjour Wine Cube Is NOT a refrigerator it has no freon it circulates air to keep wine stored at proper temperature for cellar. To chill place in fridge or get something with freon.
Posted on Oct 14, 2009
What are best dates to drink red wine?
There is no magic date. Just make sure to chill it for a hour before drinking. I know it sounds weird but that is how it is done. For white wine and it's been in the refrig. you need to let it sit a hour before drinking. Most folks drink white wine too cold and red wine too warm.
Sep 06, 2014 | Wine & Spirits
What is a cube wine rack?
Wine cubes are a versatile type of wine storage which considered being small and can fit large amounts of bottles. You should just stack bottles on top of each other allowing any type of bottle to be stored. This is convenient if many different types of bottles are being used.
Aug 13, 2012 | Furniture
My Sub-Zero 561 ice maker works fine however when it dumps ice into the tray and fills back up with water, the water pours out on the right side and into the ice tray. any suggestions
I had the same thing - turns out the wife tried to put a wine bottle in to the ice tray to chill it - in turn it had pushed the water pipe back a little too far and so was causing water to spill out - see if you can pull the pipe forward a little - you will need to remove the ice cube bin - and get in to a funny angle to get to it -but its do-able.
good luck
Aug 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
FRIDGE FAN DOES NOT COME ON
What is the cooling problem? Have you checked the fan after holding in the light / fan switch. Some fans go off when the door is open. Fan is probably stuck due to lack of lubrication. Check fan to see if it spins freely. UNPLUG UNIT BEFORE EXPOSING WIRES, be sure you are clear before plugging in while doing test runs etc.
Jun 27, 2009 | BonJour 53372 Wine Cube Refrigerator
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Bonjour wine cube #53372
Nov 10, 2007 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
