SANYO MXAM PROJECTOR REMOTE
HOW TO RESET THE REMOTE TO TURN ON THE PROJECTOR.
How can i turn on a sanyo plc-xe31 projector without a remote.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 20, 2015 | Sanyo FOR PLC-XE31
How do I change the light bulb in the Sanyo pro traX multiverse projector
unscrew the lamp door on the bottom of the projector, unscrew the lamp, remove the lamp, replace with new lamp, screw in, replace door, turn on, and reset lamp counter (menu-settings-lamp counter reset-yes)..
Nov 03, 2009 | Sanyo PLC XU30 Multimedia Projector
Would not turen back on
It sounds like you changed the remote code, which shuts the remote control off. Can you get into the menu using the controls on the projector itself? If you can, find the remote function and turn it back to the the original code. The factory set code is "code 1", this should get the remote back to normal use.
Good Luck
Jul 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XE31
Sorry if this is a bit late...
Hold down the MENU and IMAGE buttons on the remote for more than 10 seconds and the remote toggles to the other projector.
Banni
Nov 04, 2008 | Sanyo FOR PLC-XE31
Sanyo Pro XtraX Remote Code
You may have reassigned the projector/remote control codes. If you still have your User's Manual, reference page 38 and there are instructions on how to reset the codes.
If you don't have the User Manual, it can be downloaded at http://sanyoservice.com/pdf/images/PLVZ4(OM5110749-00).pdf
Please let me know if you have any questions.
Good Luck!
Aug 11, 2008 | Sanyo PLV-Z4 Multimedia Projectors
I turn the remote receiver off
I think he turnerd the remote sensor off in the menu, if you did, press the menu button on the projector itself and then go find the sensor options to turn the recievers on.  Hope this helps!
May 10, 2008 | Sanyo PLC-SW30 Multimedia Projector
Accidently hit the key lock button
Hi
You can overcome this problem by disconnecting the AC power cord, to turn off the power. Then press and HOLD the select button and reconnect the AC power cord.
This should clear the Lock.
Hope it helps
Dec 08, 2007 | Sanyo PLC XU50 Multimedia Projector
75 people viewed this question
k24674
jasbo
jasbo
