Question about Dishwashers
Miele dishwasher motor
I have a Miele Inspira Series, two of them actually ONe we have used every day since purchased and the other we used only occasionally. A few years ago the occasional use one stopped working. It would start, water would flow then all lights would flash. We kind of forgot it because it was just used for overflow anyway. I ended up having another problem with a Samsung washer and called a repairman and the company also worked on Miele so I had him take a look at the dishwasher. Turns out there was a TAZO teabag stuck in the motor- but at any rate, that tea bag caused the motor to burn out- it gets hot and the tech said I need a new motor- to the tune of over $1100....I paid $1500 for the dishwasher. We have not fixed the machine, we will probably contact Miele but I wanted to know before I do how its possible for anything to get stuck in the motor???? Looking at the machine it looks very unlikely this could ever happen. My next questions is if Miele is unwilling to aid us in fixing the machine, are there refurbished motors out there anywhere? I'm also confused because the motor does start- the machine does run, then it quits and the lights flash. I thought maybe removing the bag would be enough, but it was not. Thank you- trying to avoid either a pricey repair or having to buy a new machine.
  • 9 Answers
SOURCE: Miele Novotronic G 841 Plus keeps stopping after a few minutes
There's a rectangular slot under the triple filter at the 12 O'clock position. The circulation pump impeller wheel faces you inside that hole. I would recommend using a special wrench for doing just that. The box wrench could get stuck and break off a blade on the impeller. I think Miele will mail you the special tool for free if you call them with the Model and Serial number. They say the pump seal inside there gets tight if it's not used on a regular basis and the hot water or the tool frees it up. I think they could use ceramic washers instead of rubber. They don't change size so there would be much less tourque required to start the pump.
Posted on Apr 20, 2008
SOURCE: 3 lights are flashing at end of dishwashing cycle cycle
I shut off the dishwasher, held a few of the buttons together at the same time, let it sit for 5 minutes, then restarted it and it worked!
Posted on Mar 22, 2009
gwshaw71
  • 83 Answers
SOURCE: Circulation pump on my Miele dishwasher
Miele makes a special tool that you use to free up circulation pump.The price for that pump is about 800-900 dollars.Call miele and ask for that tool.
Posted on May 09, 2009
  • 256 Answers
SOURCE: residue and unclean dishes in a miele dishwasher
Try more or less detergent. Is rinse aid solution and detergent dispensers working properly? Otherwise, you may have an issue with quality of water.
Posted on Apr 14, 2010
  • 91 Answers
SOURCE: My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Posted on Sep 02, 2010
I have a Miele G640, the drain pump continues working even when I put the program on off.
Hi - theres a water leak to the base of the diswasher which causes the pump to run continously, you will need to determine its origin to minimize this from reoccurring.
Best way is to pull the machine out so you can tilt it backwards slightly to remove the acess panels either the bottom plate or an access panel in the front bottom of the machine to see where the leak maybe.
Aug 17, 2011 | Miele Inspira Series Dishwasher w/ 6...
Detergent tray doesn't open during operations.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 31, 2011 | Miele Inspira G2140 Dishwasher
Hi, my Miel, Inspira series dishwasher makes a very loud grinding noise for a few seconds and shuts down...
It must be trying to drain out water but the pump mechanism might be rubbing due to faulty bearing. Need full model number before I can give you more details to look for. Is this happening right at the beginning of the wash cycle?
Feb 11, 2011 | Miele Dishwashers
My brand new Miele dishwasher door wont saty down when loading and unloading - tonight was the last straw as it shot up and has really hurt my forearm!!! Please tell me what I can do to sort this out =...
you can tension the door springs or release tension by a screw at the top ....you will have to look for it check the book for directions....you probably have a model made for a door panel to be fitted and dont have the panel fitted yet...
Feb 10, 2011 | Miele Inspira G2140 Dishwasher
Model Inspira G2140 SCU There is a residue on dishes and glasses Water come on is hot but does not clean
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Miele Inspira G2140 Dishwasher
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Where can I get Miele dishwasher parts?
hi,
you will have to purchase spare parts from Miele directly or from a miele authorised dealer. you cannot purchase spare parts any other way.
if you look at www.miele.com and chose your country you will find your local Miele dealer or office
Mar 03, 2010 | Miele G892SC SS Dishwasher
Miele Inspira Series Model G2140 U All program cycle indicators are on. I unplugged the dishwasher for 60 secs. and tried a hot/pans cycle and all the lights returned. What can I do? Thanks, Leo
in this case you just have to know when you can doit or let the professional handle it. but before they come call the company and tell them that your machine has to be reset and to tell you what to press and hold to reset maybe that might work,sometimes you get a acknowledgeable person who knows a litte something something. it could save you some money on the repair.let meknow if i was of some help with a 4 thumbs up post
Feb 27, 2010 | Miele Inspira G2140 Dishwasher
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
