Question about LG P895 Optimus Vu Black Android 4.0.4 unlocked phone
My phone was updating and it stopped working i dont know how to restart my phone cause it stopped
I didnt realise what happened but all viber contacts went missing. I usually used to get intimation wwhen new contact joined viber. How to restore
i would suggest download a new version, delete the old one, restart your phone and install it again. Viber usually stop working if you dont update.
Oct 13, 2013 | Cell Phones
My phone is restarting after welcome screen. i cant update it cause i cant set the usb mode to pc suite and i cant restore settings. i tried nokia sotware updater, jaf nothing works they cant detect p
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 25, 2012 | Cell Phones
I want to flash my nokia 3110c. hw can i do it in internet
Its not possible to do via internet - You need to have a UFS based flashing box and the relevant software to do the flashing,
Mar 11, 2011 | Nokia 3110 Cellular Phone
My mobile cant view you tube videos
Hello There! Try updating the scrips, if that doesn't work, try restarting the phone.
Are you using WiFi or a GSM service? Let me know!
All the best!
Dont forget to rate! ;)
Jan 14, 2011 | Samsung B3410 Cell Phone
Have a problem with start button
Im telling the solution step by step.It ll work . you dont need to go 4 the firmware v5.05 If ur phone restarted 3 or 4 times and switched off automatically.
Try this Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu [default security code:12345] {i know most of people have done this thing,but remember u have 2 go with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]between 470kb - 499kb.
Now surely ur 3110c working fine about 5 months. During these time u can1
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime. but remember below
DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times and automatically swiched off.}
Jan 14, 2010 | Nokia 3110 Cellular Phone
I had updated my phone software today but while installing the could not restart for that reason i removed data cable,now it cannot get start
oh this the major problem. the company srictly advises you dont remove the usb cable while updating the software.. otherwise the phone will corrupted. Next time dont remove Usb cable while Updating the software. the phone restarts automatically while updation. its a common factor......
Nov 04, 2009 | Nokia 5220 XpressMusic Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
months.During these time u can
but remember below DONTs
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 | Nokia 7610
Switch on key stopped working and Nokia Sw Update dont recognize it anymore
Try a software reset, just make sure your contacts are backed-up first. It could either be *#7780# Restore factory settings or *7370#
Nov 29, 2007 | Nokia 6288 Cellular Phone
LG P895 Optimus Vu Black Android 4.0.4 unlocked phone Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
