Question about Car Audio & Video
HOW TO REPLACE BATTERY IN BESTMED KD-204 THERMOMITOR
Why cant I login to bestmed
Phone Bestmed office or email for assistance.
http://www.bestmed.co.za/contactUs
Pretoria (Head Office)
Cape Town
Durban
Port Elizabeth
Randfontein
Virginia
Welkom
Nelspruit
Mar 08, 2018 | Computers & Internet
Is there anyway to check the thermostat in a 2003 Ford zx2?
Depends what you are asking ,, if you want to try Checking while on the car..take off the radiator cap..And set the Heater to full on position start the car and let it idle most are set to open at 190-95 degree temp..there is no flow through the rad or heater core unto the thermostat opens..once you see flow in the rad or feel heat in the heater you know it is open.you can also feel the hose coming out of the thermoit will be warm then hot...if you are asking what temp is it opening you must take it out " cold engine" and put it in a pan of water using a thermomitor test the temp of the water and when it gets close to the operating temp of the thermostat watch close for the spring on the thermostat to open the slidevalve inside the thermomitor..if close to the degree it is ok..too much too less it needs replaced...note the temp is usually stamped on the end of the thermostat...good luck.
Oct 01, 2014 | Cooling System for Ford Escort ZX2
I. need a manual for a.bestmed KD-2201/ digial temple thermomenter
Make sure it has batteries, Press the power button and it should beep. Wait till it beeps twice and place it on the temple area of the head. IT will beep one longer beep when it has the temp.
Sep 21, 2014 | Office Equipment & Supplies
I have a BESTMED, LLC. Golden, co 80401 KI-8160/INFRARED EAR THERMOMETER its supposed to switch somhow from celcius to farenheit and vise versa well my instructions are long gone and my daughter switched...
For BESTMED KI-8160: The C and F mode can be switched by turning the unit on then pressing the START/STOP again immediately and holding it down. The display will show "CH" with "F" or "C". Release the button when the mode you desire is in the display window. The unit will show "L" with the degree sign and the smiling face symbol in the display and is ready to take a new temperature reading.
Feb 17, 2011 | Health & Beauty
I need the set-up instructions for the JS-204 bike computer
To set up your JS-204 it's not necessary to take off the battery
Let the battery in place and press together the 2 switchs (Mode and Select) during 2 sec. and you will be able to reset your computer
Jacques de Neuville
Mar 07, 2010 | Cycling
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
Where is the batter on a Meridian 204 tuner
A 3.6 volt 150 mAmp/ hour NICAD battery is soldered to the bottom PCB Com board
Apr 14, 2009 | Audio Players & Recorders
Oven themostat not set correctly
Your thermomitor may be going or the oven sensor could be the problem. Buy a BRAND NEW thermomitor and put it in the middle of the middle rack and set to 350. After the preheat is done, wait another 10 min and read thermomitor with flashlight through door glass. This will be the MOST accurate way. to tell
Mar 26, 2009 | Kenmore Kitchen Ranges
Car Audio & Video Logo
128 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
