1998 Ford Explorer Logo
Posted on Mar 29, 2009
Number pad on door
Is there anyway to reset the number pad on the door of a 98 Ford Explorer?
  • reader402 Mar 30, 2009
    Thank you. Will give it a try
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
258
Points
Yes, but you need the factory code also. First enter the factory code (5 digits), then press the 1/2 button, then enter your own 5 digit code. You can use either code now, but there is noo way to erase the factory code.
Door handles wont open doors
Fixed 1997 Ford Explorer Door wont open - YouTube
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
98 Ford Explorer Door Won't Open Part 1 - YouTube
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
98 Ford Explorer Door Problems- how to open without panel ...
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
Rear doors can't open from inside - Ford Explorer and R
Just bought a 1999 ford explorer xlt don't have
You need a NGS (Ford factory scan tool) They can access the RAP KEYCODE PID.
2helpful
Can the number pad on door be reset
no, the only way to reset it would be to replace the module for it, i think the dealer with the vin number can tell you the code for the control, good day.
2helpful
2answers
Drivers door does not lock
you will have to remove the door panel, check for a disconnected linkage or a broken door latch, sometimes it just needs cleaning and lube, good luck.
2helpful
My horn wont stop honking
you should have 2 fuse blocks, 1 under the hood and 1 inside vehicle near drivers side door or under dash on drivers side. anyways the fuse number for the horn is fuse number 10, however, i am not sure which fuse block this fuse is in, i think it is the inside the vehicle fuse block.
2helpful
2answers
Am just wondering if a 98 explorer 2 doors has same alternator as 99 explorer 2dr?
Just get both generic part numbers from autozone or O'Reillys. If you use the Ford numbers the year number can show a different number in their part number sequence. Whether you can see the Amps rating on the alternator without removal is iffy.
Numeric door codes
you can find the keyless entry codes for the number pad, to unlock and lock your truck, on the keyless entry module, located under dash left side, the code will be the numbers in bold print, these are the factory code numbers
Change door code on 98 explorer
You will have to find the program code which is located on the processor either in the right front glove box area by the kick panel or in the left rear compartment when the hatch is open...you will see the 6-8 digit security key numbers and enter them on the key pad wait for thebeeps to begin and put your code in quickly befor the beeps end. I would be more specific but as I remember It varied for different models also I worked at Japanese dealerships along with Ford.
Security System in 98 Ford Explorer
they have to be prorammed by the dealer only
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
