Blyss 12000 btu/3500w - Heating & Cooling
  • 45 Answers
SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Posted on Jun 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: Hi i have a Maytag 12000 btu Window ac unit that
I had a similar problem with my AC last week. These newer capacitors no longer have PCBs in them. The stuff they use now just ain't as good. As a result their are more capacitor failures tan ever. I would check that. If the cap looks swolen its probably bad.6f0f1c5.jpg52ae98e.jpgYou should also try and lubricate the motor. Use HVAC oil 106f87c.jpg$2 at Ace hardware store.
You gonna have to slide out the unit a little to get to the motor. Have rags ready.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 18, 2010
  • 5 Answers
SOURCE: Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Posted on Jul 09, 2010
heatman101
  • 43501 Answers
SOURCE: Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Posted on Jul 21, 2010
Testimonial: "Thanks for the speedy reply and your time."
  • 230 Answers
SOURCE: Where does the water drain
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Posted on Jul 02, 2011
How can I find out how many BYU’s my Maytag A/C unit is?
12,000 BTU
Maytag M6Y12F2A 12000 BTU Air Conditioner ' comparical.com
air-conditioners.comparical.com > Air ConditionersMaytag M6Y12F2A 12000 BTU Air Conditioner is a Thru-Wall/Window air conditioner which has an energy efficiency rating of 9.8 EER and a cooling capacity of ...
maytag air conditioner m6y12f2a specs Google Search
May 19, 2018 | Computers & Internet
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
Idylis 12000 btu manual
Find more information on this link:
http://pdf.lowes.com/useandcareguides/840206110031_use.pdf
Jul 13, 2013 | Heating & Cooling
Tempstar 5000
The 48 before the VKD in the model number stands for 48000, BTU. For refrigeration, 1 Ton = 12000 BTU. Therefore 48000 BTU / 12000 (1 Ton) = 4 Tons
May 03, 2013 | Heating & Cooling
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
Jun 20, 2012 | GE 12000 Btu Room Air Conditioner EnerStar...
HOW MANY TONS IS THIS UNIT WEATHER KING 10AJA4801AH?
It's a 48,000 BTU AC - so 48,000 divided by 12000 = 4 tons
Note: 12000 BTU = 1 ton of air conditioning
Jun 10, 2011 | Weather King 10AJA4801AH Air Conditioner
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
Jun 06, 2011 | Samsung AW0603B Air Conditioner
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
